Author Topic: 280 SE engine mounted in a pagoda  (Read 7623 times)
ola
« on: March 18, 2012, 20:28:51 »
w 108 1970. mod. 280 se engine mounted in a pagoda. But it's serious amount of gasoline it seems.
 Could probably have needed a good adjustment insprøytningen.
 how do you do this?
 who adjusts the insprøytnings pumps?
 it can adjust without it being in the engine?
« Last Edit: March 19, 2012, 08:19:29 by 280SL71 »
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
Ola,
What Miles Per Gallon are you getting?  15 to 17 mpg in the city and 19 to 21 mpg highway driving is good for these cars.  (Sorry I don't have a metric conversion chart handy)  We need more explanation of your problems to offer suggestions.
There are several threads on this site about the Fuel Injeciton Pump.  Some deal with adjustment and others with overhaul.  You really need to understand the entire Fuel/Ignition relationship on these cars.  It is complex and takes some time to master.
ola
where do I buy a reconditioned?
 price?
Tom Colitt
Re: 280 see engine mounted in a pagoda
« Reply #3 on: March 19, 2012, 06:05:10 »
Ola. As a rule of thumb 90% of the people do not need there injection pumps completely rebuilt. Often getting them back near the factory settings, (linkages, venturi, ignition, warm running device, etc.) makes a huge difference. You should have no trouble using the 280SE engine.... Just don't use the engine mount from the 280SL in the Pagoda....
ola
« Reply #4 on: March 19, 2012, 08:05:32 »
280 engine is mounted in the Pagoda. spend a lot of gasoline
Tom Colitt
Re: 280 SE engine mounted in a pagoda
« Reply #5 on: March 21, 2012, 23:27:47 »
How are the spark plugs. Very Black?.....
ola
« Reply #6 on: March 22, 2012, 08:17:43 »
Very Black
hkollan
  • Spain, Castilla-La Mancha
« Reply #7 on: March 24, 2012, 06:11:21 »
Hi Ola,
In Norway, Oppegård elektrodiesel used to be able to do adjustments and rebuilds on these injection pumps, but unfotunately as of
lately thats not possible anymore, since guy who did this is now retired. Koller und Schwemmer in Germany can do this
if that is what really is needed. They only do complete rebuilds and i think they charge around 4-5000EUR for a pump for the pagoda.
But as Tom suggests there are a lot of items that should be checked before you decide to pull the IP.
Hans
Hans K, Cuenca, Spain
ola
« Reply #8 on: March 24, 2012, 07:28:36 »
you have a link / address Schwemmer in Germany
jacovdw
« Reply #9 on: March 24, 2012, 19:30:28 »
Here you go...
http://www.koller.de/
twistedtree
  • USA, VT
« Reply #10 on: March 24, 2012, 19:53:49 »
If a rebuild really costs 4000-5000 EU then it's probably worth sending it to the US where it can be done for $1200 which is sub 1000 EU.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« Reply #11 on: March 26, 2012, 00:19:43 »
I have a pump R24Y I have tested runs great $750.00 plus shipping let me know.
Bob "Baron" Youngman
1965 220se coupe restomod
Tom Colitt
« Reply #12 on: March 28, 2012, 02:19:24 »
It's sounds like you're running rich. Try removing one of the thin washers that are between the cylindrical vacuum box next to the warm running stack and the top of the injection pump. The less washers the leaner the mixture across the whole range....
ola
« Reply #13 on: March 28, 2012, 08:38:26 »
Pictures
Tom Colitt
« Reply #14 on: April 01, 2012, 20:22:48 »
It is a fairly big cylinder, right on top of the injection pump and next to the warm running stack with the two 19mm coolant hoses. You need a flattened 19mm (or22?) to loosen it from below the cylinder...
