Author Topic: Advice needed - torque converter  (Read 5216 times)
franjo_66
  • Australia, NSW, Point Piper
« on: March 17, 2012, 04:09:10 »
Well I had a bit of bad luck today. Torque converter has split in two. Mine is the aluminum version, and I am sceptical as to whether it can be repaired. Am I able to use the later steel version ?
My car is a 1965 build 230SL. Chassis number is 113-042-22-009057
I see that adsitco sell rebuilt ones, but don't specify if they are aluminum or steel.
Any advice as to whether I can use the steel version or otherwise is appreciated
Frank
Franjo
1965 230SL Black/Auto/RHD
2005 Porsche Cayenne Turbo
1983 BMW 735i
1986 560 SEC
1991 500SL
1982 Holden Statesman DeVille
Re: Advice needed - torque converter
« Reply #1 on: March 17, 2012, 04:21:31 »
I'm pretty sure they're different and you have to use like for like. It's rare that it would split in two like that. ???
« Reply #2 on: March 17, 2012, 05:34:28 »
Seems to me that some of the aluminum converters used a four bolt hook up to the engine flywheel flex plate and the steel ones used a six bolt hook up. If this is the case, a steel converter would definitely not even bolt up. A good used aluminum converter could be an option?
franjo_66
« Reply #3 on: March 17, 2012, 06:06:32 »
Thanks for confirming Dan & Joe.
I couldn't believe how that converter split like that. It was as though it was precision cut with a steel lathe !
Will get a rebuilt aluminium converter and hopefully that will be it. Auto had always performed perfectly, and there was never any debris or shavings in the fluid when doing a service. In fact fluid always looked clean.
Oh well, these things happen I guess
Reds
Frank
Franjo
1983 BMW 735i
1986 560 SEC
1991 500SL
« Reply #4 on: March 17, 2012, 09:48:53 »
The aluminium ones are well known for failing. The steel ones are a direct replacement IF you have the same bolt pattern. If not you can swap the flex plate to take the steel converter.
franjo_66
« Reply #5 on: March 17, 2012, 10:52:27 »
Hi stick, yes I think the aluminum converters came in an early 4 bolt version and then the 6 bolt version. The steel converters were all 6 bolt versions.
So if I am understanding this correctly, I can use the steel version if I have the aluminum 6 bolt converter, otherwise I need to get the matching flex plate as well if I have the 4 bolt version
Thanks for the heads up
Frank
Franjo
1983 BMW 735i
1986 560 SEC
1991 500SL
« Reply #6 on: March 17, 2012, 14:00:41 »
Also be aware that there are riveted hub steel converters and the later welded hub converters which are interchangeable.  The welded hub steel converters never leak.
« Reply #7 on: March 17, 2012, 14:09:45 »
Joe mentioned the riveted hub steel converter. If you do get one where the snout is riveted to the body have the seam and around the rivets welded. I only had to pull my transmission 3 times to learn that.
franjo_66
« Reply #8 on: March 18, 2012, 02:17:09 »
Guys, thanks for all the advice and tips.  It is much appreciated!
Reds
Franjo
Franjo
1983 BMW 735i
1986 560 SEC
1991 500SL
