Author Topic: Serial number positions for gearbox and diff  (Read 5932 times)
rutger kohler
« on: March 05, 2012, 03:44:53 »
Hi, I would like to note the serial  number for the gearbox and diff on my 280SL. Could someone plse direct me to a photo of both positions so I can check them.
rutger kohler
Re: Serial number positions for gearbox and diff
« Reply #1 on: March 07, 2012, 08:21:05 »
I've had a lot of members look at this but no replies, perhaps I have not been clear enough so here is another attempt!  As I understand it each gearbox and differential housing has a unique serial number, just like the engine. I have a small owners parts book which shows the approximate position of the serial number' on the gearbox bell housing, and the diff housing' but when I look on my car, I can't see them.  I am hoping someone else has taken a phot uder their car, of their serial numbers so that I can see where they are.  Hope this clears my request up.
Larry & Norma
« Reply #2 on: March 07, 2012, 10:11:12 »
Auto or manual?
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
« Reply #3 on: March 07, 2012, 10:27:07 »
Rutger,
I am not sure but think that the number is stamped on the dif near where the ratio number is also stamped on the left bottom rib.
http://www.sl113.org/forums/index.php?action=dlattach;topic=13717.0;attach=8664;image
twistedtree
  • USA, VT
« Reply #4 on: March 07, 2012, 11:26:14 »
This should help.  The lower number is the gear ration, and the upper number is the SN.  This is an early 230, and I can't say whether the numbers have moved in later models.
As for the transmission, on an automatic there is a tag on the lower left side of the gear case, just above the oil pan.  I'm not sure about 4 speeds.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
« Reply #5 on: March 07, 2012, 12:06:40 »
Hi, Rutger,
Garry is right, on the 280 SL the serial # precedes the diff ratio on the lowest left rib of the casing.
On the 230s, its on the back housing as indicated by twistedtree.
I don't know where the serial # is stamped on a manual box but I believe there is a plate riveted on the rectangular block in the picture on the auto.
Naj
« Last Edit: March 07, 2012, 14:32:56 by Naj »
rutger kohler
« Reply #6 on: March 07, 2012, 21:49:02 »
thanks guys, that's sorted the diff, the gearbox is 4 speed manual.
