Author Topic: Removing the Shifter Ball  (Read 6300 times)
SilverSpear
  • Abu Dhabi, UAE
« on: January 03, 2012, 07:00:53 »
Hello guys,
I am trying to remove the ball on top of the shifter handle, but for some reason it wouldn't come off.
Can anyone please guide me through?
Early 1967 Pagoda 250SL - Under comprehensive restoration
Euro 2013 Mercedes 350SL
Ulf
Re: Removing the Shifter Ball
« Reply #1 on: January 03, 2012, 08:08:47 »
It should come off quite easily, try tapping it gently from beneath with a hammer and use a piece of wood in between.
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
SilverSpear
  • Abu Dhabi, UAE
« Reply #2 on: January 03, 2012, 09:37:26 »
I wanted to tap it from underneath but I was afraid that it is screwed from inside the ball.
It is moving up and down by like 4mm, but that's it no matter how much I try to take it off from the stick handle.
Larry & Norma
« Reply #3 on: January 03, 2012, 10:14:19 »
I use a pair of loose fitting pliers with some rag in the jaws to protect the shaft and ball and slide them up the shaft
to strike the gearshift knob. It will come off it is only a push fit. It may be neccessary to tap the pliers upwards
with a hammer.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
Iconic
  • USA, IL, Highland Park
  • ex-Membership Administrator
« Reply #4 on: January 03, 2012, 15:41:30 »
SilverSpear,
Do you have an automatic trans or a manual?
What Gnuface is describing is perfect for the automatic ball. It comes right off that way.
I don't know how the manual shift ball is removed.
1998 BMW M-Rdstr Estoril Blue
IXLR8
« Reply #5 on: January 03, 2012, 16:25:58 »
Hi-
The manual ball removes the same way as the automatic one.
the other Joe
SilverSpear
  • Abu Dhabi, UAE
« Reply #6 on: January 03, 2012, 17:11:04 »
Ok guys will give it a try in few minutes...
Will let you know what happens
SilverSpear
  • Abu Dhabi, UAE
« Reply #7 on: January 03, 2012, 18:22:47 »
Thanks Fellas!
Ulf
« Reply #8 on: January 04, 2012, 08:45:01 »
2008 Jaguar XF 3.0
2005 Mini Cooper
« Reply #9 on: January 04, 2012, 19:59:50 »
Haha! Maybe this will start a trend, "if there's no photo it didn't happen!"
PeterW113
« Reply #10 on: January 05, 2012, 20:01:04 »
Good to see that you were successful, out of interest on my 68 280L Auto, the knob unscrews. It had me fooled for a while as most references to removing the knob all suggest tapping it off as described above.
1968 MB 280SL, RHD Auto
1968 Lotus Elan +2
1962 Ford Thunderbird
2007 BMW 1200 GS
SilverSpear
  • Abu Dhabi, UAE
« Reply #11 on: January 06, 2012, 05:03:28 »
haha yeah... pictures... or it didn't happen!
