Author Topic: Chassis/Firewall Intersection Detail  (Read 5350 times)
Steven A
  • Australia, Western Australia, Cottesloe
« on: August 09, 2011, 12:38:07 »
Hi
I am repairing a rusted box section in the firewall above the main frame rail, and immediately next (outside) to the fresh air vent cavity.   Looking forward from the passenger floor, there are 2 rectancular openings, and what appears to be the remains of a bracket,   Vehicle is a 230SL 1964
Any information as to how the firewall interects/joins the main frame would be appreciated.   I am not sure if the 2 rectangular openings should be covered, and whether there should be a "L" or other bracket to re-inforce the section.
I have a sketch (plan view, and looking from passenger floor) which I can email to anyone if they could assist (having problems attaching sketch to this post).
Thanks for help, has been good info and helpful
Regards
Steven
1964 230SL Manual RHD
1957 Series 1 Land Rover
1975 Range Rover
Re: Chassis/Firewall Intersection Detail
« Reply #1 on: August 09, 2011, 16:22:28 »
Hi Steven,
a photo or sketch would be really helpful. Perhaps these instructions will help you with the posting:
http://www.sl113.org/forums/index.php?action=help;page=post
And the forum tutorial here: http://www.sl113.org/WebsiteTutorials.html
Steven A
« Reply #2 on: August 09, 2011, 22:58:26 »
Hopefully attacment now included
Thanks for help
Steven
1975 Range Rover
« Reply #3 on: August 10, 2011, 04:37:48 »
Congrats - the attachment worked, but I cannot figure out where these holes could be.
I assume you have a LHD car, or is it a RHD?
Attached are 3 photos from a 1966 230SL (LHD), perhaps they might help you locating your rectangular openings or the L-bracket.
Steven A
« Reply #4 on: August 10, 2011, 11:14:00 »
Thanks for photos, appreciated
Section in question is immediately in front of footwell, just under where the lower dashboard frame ends (as per blue arrow on attached marked up photo, but on the frontside of the footwell wall).    What is the structure between  engine bay firewall side and inside of passenger floor/footwell, and also between the engine bay firewall side and the front end of the intrument/dashboard etc framework
The car is 1964 right hand drive, manual transmission.   Setch is of left hand side of vehicle.
With thanks, and regards
Steven
1975 Range Rover
« Reply #5 on: August 10, 2011, 13:21:27 »
Steven,
Some pix from a RHD car that may help.
Naj
Steven A
« Reply #6 on: August 10, 2011, 13:28:36 »
Naj, thanks, very helpfiul
Regards
1975 Range Rover
