Author Topic: 280SL Ride Height  (Read 6381 times)
280SL Ride Height
« on: May 20, 2004, 09:51:18 »
When new, the 280sl rear stance, appeared to be higher in the rear than front, with the body high above the wheels, and from the rear, the two wheels were canted inward, when empty and light.
Now the car sits very low in the rear, and there is very little wheel cant. Does this mean I need new shocks, springs?? How do I tell what the culprit is?
blairwag
Re: 280SL Ride Height
« Reply #1 on: May 20, 2004, 10:49:21 »
Well, unless you are using air-shocks to lift the rear of the car - which the SL's ooriginally did not - and you shouldn't either, then the shocks themselves have very little (if at all) to do with the rear ground clearance (ride height). If you feel the car is sitting down lower than it should, or lower than you like, then the rear springs are undoubtedly the area of initial concerns. Check also all bushings for crushing.
1971 280SL US Automatic
mulrik
« Reply #2 on: May 20, 2004, 12:51:02 »
I had the same concern with my car. Turned out my shock absorbers were broke and that the lower rubber insulaters in the back were also broke. I changed the four shock absorbers into Bilstein originals and the rubber in the back. I measured my vehicle height with hard top on and bang, it was the specified height. So don't worry about the springs it's the other parts of the suspension you should check.
All the best from
« Reply #3 on: May 20, 2004, 13:19:02 »
I would check the rubber pads on either end of the springs - both Per and Blair report having replaced these and they do influence the height.
« Reply #4 on: May 21, 2004, 16:01:39 »
Don't forget to check the compensating spring pads.  Mine were shot along with the lower rear coil spring pads which are all subject to salt, dirt, rain etc.  The upper pads are protected but over time they can compress some.
« Reply #5 on: May 21, 2004, 16:44:10 »
Does anyone have the part numbers for the pads, so that I can have my dealer order them before I take it to the shock shop?
« Reply #6 on: May 22, 2004, 04:26:27 »
check the K&K online catalogue under "Suspension", use the OLD catalogue because it gives the correct parts numbers.
http://www.kkmfg.com/
Bob (Brisbane,Australia)
« Reply #7 on: May 22, 2004, 12:15:26 »
There are several different thickness pads on the rear and front.  Two different thickness pads for the compensating spring.  Spring lots and pads were matched in the factory based on options like A/C, auto versus manual etc. to achieve correct ride height.
All five springs are color coded and you will notice various paint stripes on the mid section of each one.  If you can tell me the number and color of the stripes on your springs I will refer to the BBB to see if I can determine the correct pad part number.
« Reply #8 on: May 22, 2004, 14:34:59 »
SD280, Did you purchase car this way? If so the previous owner(s) may have fitted it with shorter springs. My 69 has these particular springs shorter stiffer & approx 1" lower. check this out  http://www.geocities.com/tomsargent/Restoation.html   Excellent job Tom!!
« Last Edit: May 22, 2004, 14:43:10 by hauser »
