Author Topic: Electronic ingnition conversion  (Read 6333 times)
jmbour
  • France, Ile-de-France, Paris
« on: July 21, 2011, 13:23:29 »
I have seen an add for "Hot spark " electronic conversion ignition ( 3BOS6U2L part recommended for 280 SL at 59.99 US D).
Does anybody has an experience with this conversion ?
Is it necessary to replace also the coil ?
J.M.  Bour
JMB
1971 280SL US
1973 280CE
1987 300 E
2005 C230
Re: Electronic ingnition conversion
« Reply #1 on: July 21, 2011, 16:16:01 »
I've never heard of this product but can recommend the '123' ignition (see other threads) - it replaces not only the points but also the entire distributor with a new one. Ignition issues are often caused not so much by the conventional points system but by wear in the distributor. With the 123 product you convert to electronic ignition as well as eliminate any potential problems caused by a worn distributor.
When I installed mine a few years ago, I noticed a marked improvement in the engine running characteristics - and this is compared against an electronic ignition conversion and a rebuilt conventional distributor.
  • USA, WI, Mequon
« Reply #2 on: July 21, 2011, 17:13:37 »
I have a "hot spark" in my 190 SL, essentially the same as the Pertronix.  Electronic points.  If you search Pertronix on this site you will find some discussion.
jmbour
« Reply #3 on: August 05, 2011, 09:55:21 »
Thanks, I note that 123 ignition replaces the whole distributor.
Hopefilly, it is available in France.
Jean michel
JMB
1971 280SL US
1973 280CE
1987 300 E
2005 C230
jacovdw
« Reply #4 on: August 05, 2011, 10:23:15 »
Jean,
According to their website, they have a couple of distributors in France.
Have a look at this link and scroll down a little bit to find your country:
http://www.123ignition.nl/buy.php
Hope this helps.
IXLR8
« Reply #5 on: August 05, 2011, 18:35:26 »
Hi John--
You said that you have a Hot Spark in your 190SL.
How is it working?
I have a Pertronix in my VW type 181 as I had heard that the Hot Spark had reliability issues. No problems with the Pertronix, but twice the price of the Hot Spark.
Joe
philmas
« Reply #6 on: August 09, 2011, 14:49:12 »
Jean michel
Hi Jean Michel !
You can also order  the 123 ignitor from SLS .
I see you're living in Paris as I do.I would be interested in your opinion and experience about dealers and workshops in this area (PM)
Philippe
Philippe from Paris
Euro '71 280SL manual 4sp
jmbour
« Reply #7 on: August 10, 2011, 16:04:47 »
Philippe,
I got my SL in the US, and found that it is easier (and a lot more cheaper) to buy classic MB parts in the US than in Europe.
You need only to be carefull with the reference of the parts, in order to be sure that you order the good one (on the internet).
In France,  SLS is well known, but you can also ask Mercedes classic through your local MB dealer (in Paris "Mercedes Lonchamps"). I have also found "Niemoller" (www.niemoller.de) in germany, but some parts are also available from general discounters like "Oscaro" or "Webdealauto".
So, get on the internet, and do your shopping !
Jean michel
JMB
1971 280SL US
1973 280CE
1987 300 E
2005 C230
