Author Topic: courtesy light door jamb switch  (Read 12411 times)
shanghaitom
« on: July 08, 2011, 02:28:45 »
Hello all.  I have a 1970 280sl and, during restoration, I broke both door jamb switches through stupidity.  In looking to replace them, I found that the passenger side has two "poles" or contacts, but the drivers side connection is four pole.  Can someone tell me what the purpose of the additional contacts are for?  Replacing the passenger side is <$30, the driver's side is >$100  :o
Would it make sense to replace the driver's side with a standard two pole switch?
Thanks!
Larry & Norma
Re: courtesy light door jamb switch
« Reply #1 on: July 08, 2011, 09:13:21 »
I thought that they were both the same on mine, but looking at a circuit diagram there are extra contacts on
one side for an intrusion alarm/buzzer. I am sure my car does not have it.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
scoot
  • USA, CA, Altadena
« Reply #2 on: July 09, 2011, 03:50:06 »
Thanks!
I've never seen one with 4 poles...
Scott Allen
'67 250 SL (early)
Altadena, California
« Reply #3 on: July 09, 2011, 04:29:32 »
Just a thought but could it have to do with the extra light that comes on the dash when the door is open with 280SLs -- and some how the brake level warning? Earlier cars don't have such features.
« Reply #4 on: July 09, 2011, 04:35:24 »
Mine is a '69 280SL but only has the two pole switch on the doors!
Larry & Norma
« Reply #5 on: July 09, 2011, 08:11:17 »
Circuit attached, 16 and 17 are the door switches.
2023 Ioniq6
2005 C230
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #6 on: July 09, 2011, 13:27:04 »
The 280 SEL 4.5 I just parted out had a 4 pole on the drivers door.  I sold that one already.  I'll have to look to see if I still have one from the first parts car.  If I have it I'll let you know.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
scoot
  • USA, CA, Altadena
« Reply #7 on: July 11, 2011, 14:47:08 »
...but those look from the picture to be plastic, not metal...   Do late 113 cars have plastic door-open switches?   And are the 4-terminal variety difficult to come by?
Scott Allen
'67 250 SL (early)
shanghaitom
« Reply #8 on: July 11, 2011, 16:36:03 »
Yes, the later models have plastic switches.  Both are readily available.  I bought the 2 pin off amazon and the 4 pin are available from many general auto supply stores by order.
scoot
  • USA, CA, Altadena
« Reply #9 on: July 12, 2011, 14:33:42 »
....but in plastic (echh).  Is there a metal 4-pin switch, and what does it do?
Scott Allen
'67 250 SL (early)
scoot
  • USA, CA, Altadena
« Reply #10 on: July 12, 2011, 14:36:26 »
So is the difference shown in the wiring diagram that the second set of door contacts activates a warning buzzer, assumedly if you leave the keys in the ignition and open door and/or leave the lights on and open the door?    Save our eyes and tell us the answer if you know it please.... Thanks!
Scott Allen
'67 250 SL (early)
« Reply #11 on: July 13, 2011, 12:34:28 »
Hi Tom,
Here is a picture of my 4 pin switch.
Came from a 1970 280SL.
Walter
scoot
  • USA, CA, Altadena
« Reply #12 on: July 13, 2011, 13:52:52 »
OK.  I snagged a 4-pin door switch at the junkyard yesterday off of a 108.  Still scraping the blue paint off it from the bad re-spray...
Scott Allen
'67 250 SL (early)
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #13 on: July 13, 2011, 14:11:50 »
Scoot, You are lucky to have a junk yard with any MB in it.  There is no such place in western Pa
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2025 E53 AMG Sedan
