Please check out joining the
Emergency Contact List
for help during your travels!
Crankshaft damper
Topic: Crankshaft damper (Read 3829 times)
Vendor
Platinum
USA, TX, Dallas
Crankshaft damper
July 06, 2011, 16:26:06 »
Do most people typically replace the crankshaft damper after 40+ years? Being that it is a rubber sandwich, it would seem that the rubber would degrade like all the other engine compartment rubber.
Thanks!
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Crankshaft damper
July 06, 2011, 23:48:07 »
I haven't had any problems with them. If it looks damaged then I would get another one.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Wing
Reply #2 on:
July 07, 2011, 07:55:27 »
I just discoverd that mine is worned and must to be replaced. A new one cost € 540,- (in Holland). I found a used one in good conditions for € 150,-.
Crankshaft damper
