Author Topic: grille screw discrepancies  (Read 11544 times)
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
« on: May 15, 2011, 20:50:55 »
Hello All,
 I recently acquired a set of cupped finish washers from Germany for the eight grille surround attachment screws.They have an M-B part number and packaging, but they do not look quite right.
I have always believed that when an oval head screw is pocketed down into a finish washer, the dome of the screw head should be flush with the cupped edge of the washer.  After all these years of designing and building things - - - am I wrong about this ?
The photo of the screws I bought says it all. Not only is the screw head too big , but why is a zinc plated screw mated with a stainless steel washer ?  Needless to say, his will never get  past a Concours Judge inspection team. I should know - -  Pete Lesler trained a group of us last summer.
On my car the drilled hole that accepts these screws  is way over-sized now, the result of  previous owners using #12 sheet metal screws instead of the proper #10's ( or should they be #8's ?).  To get back to the way it should be, I am going to have to install a Tinnerman nut-plate or make something that will do the job.
In my nuts and bolts bins I have been able to find suitable replacements for the screws, see photo, so I am forging ahead.
Regards, Larry in CA
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
Re: grille screw discrepancies
« Reply #1 on: May 15, 2011, 22:32:07 »
Larry,
I have just had the same problem with my grill and replaced the wrong screws from the body shop with what I think are the correct screws but had the enlarged holes problem.  I used Joe A's method of using a piece of copper wire in the hole to start with the screw and it worked a treat and the screws gripped and the copper does not show.
« Reply #2 on: May 16, 2011, 04:33:03 »
Hi Larry,
not sure whether I am understanding your question. Did you buy the cup washers and the screws together or are the from different sources? If you bought the together then the seller made a mistake.
First, the screws should not be gray steel but chromed and should be oval not a pan head - but it is a bit difficult to see what their profile is. What is the p/n on the bag? The should be neither a #10 nor a #8 but a metric DIN screw!!  The cup washers your photo do not look correct either.
Do you need the correct p/n for the cup washers and the screws?
This shows what the cup washers should look like: http://cgi.ebay.de/370502537270
and here are the matching screws: http://cgi.ebay.de/370502537322
« Last Edit: May 16, 2011, 04:56:51 by 66andBlue »
« Reply #3 on: May 18, 2011, 01:38:02 »
Thanks for pointing that out. I bought the same set a year ago and never looked at them just threw them up on the shelf with the grille. Now I am looking for chrome DIN screws.
« Reply #4 on: May 23, 2011, 00:39:39 »
In case it may help, here is a photo of a Grill screw thaat was pronounced "correct" by long time judge of Pagodas.
Richard M, NYC
« Reply #5 on: May 23, 2011, 03:22:59 »
I thought the screws were meant to be chrome plated.  The screw looks like it is zinc plated?
  • USA, WI, Mequon
« Reply #6 on: May 23, 2011, 12:09:08 »
I can safely say that mine are original and look like 280SL71 above.
« Reply #7 on: May 23, 2011, 18:07:15 »
John,
unless you're taking your car to a MBCA event where it will be judged by '' trained '' experts, what real difference does it make? Aside from knowing that you have a perfect, correct car, who's going to see it, or care for that matter?
 I mean, it's not like we ( the web forum members ) have a dedicated car show or judged events, right?
  • USA, WI, Mequon
« Reply #8 on: May 23, 2011, 18:36:34 »
John,
That's a fair statement and someday maybe there will be a clublike judging that is fun and educational.  Some folks want to be correct for their own enjoyment (bragging rights?) and I just offered mine as a high likelihood of being correct considering its history.  They appear to be the same as what's used on my 190 SL.
« Last Edit: May 23, 2011, 18:38:22 by thelews »
« Reply #9 on: May 23, 2011, 19:48:51 »
So, are the screws chromed or Zinc plated?
Dave
« Reply #10 on: May 27, 2011, 12:38:36 »
Hi All
New Pagoda owner here.  I have sheet metal screws in my grille and my cowl vent (duh! - who would do that?).   I've replaced a few missing tinnerman nuts, etc. but here's my question -
On the top of the cowl vent, I have an empty hole.  Is there some sort of fastener that goes in there?  If so, what's it supposed to do?
« Reply #11 on: May 27, 2011, 13:59:17 »
Hi All
Windscreen washer jet!
Naj
  • USA, WI, Mequon
« Reply #12 on: May 27, 2011, 22:31:30 »
Looks like chrome to me
Dave
« Reply #13 on: May 27, 2011, 22:41:13 »
Thanks Naj.  Looks like I have some work to do.
« Reply #14 on: May 28, 2011, 00:54:42 »
Perfect John, you get a price.  ;)
The p/n for the screw is 007983 003216. That means DIN 7983 and DBL (Daimler Benz Liefervorschrift=supply spec)) 8454 which specifies a lens head counter sunk screw, 3.9 x 13 mm, finish: chrome.
The p/n for the counter sunk washer is N900056 003507  - about $3/each from MB - ouch!
jaymanek
« Reply #15 on: May 28, 2011, 20:29:50 »
I recently replaced mine with parts from mercedes and have the ones like the red car above, both the countersunk washer and screw are chrome..
benz55
  • USA, NY, Staten Island
« Reply #16 on: June 10, 2011, 14:38:17 »
Im fairly sure the screws and CS washers should all be chromed. There is a kit below with the correct MB parts for reference.
http://www.authenticclassics.com/Grille-Installation-Kit-for-Mercedes-230SL-250SL-2-p/auth-002998.htm
1966 230SL / 4 Speed / Black / Black MB-Tex
