Author Topic: Rubber stripping on middle of side doors for ding protection  (Read 8896 times)
mcreasy
« on: December 12, 2010, 22:46:10 »
I was wondering if there was a proper way to put on the rubber stripping for ding protection and if it needed to be glued in place? Thanks Mary 230sl "67"
« Last Edit: December 13, 2010, 20:36:42 by 280SL71 »
reggie
  • United Kingdom, England, Leeds
Re: Rubber stripping on middle of side doors for dinge protection
« Reply #1 on: December 12, 2010, 23:14:14 »
Mary, have a look at my photo's, Mine have metal strips, With rubber inserts, Dont think there mercedes part's though, I may be wrong.
Reg
1969 280 5 speed zf 180g
Jordan
  • Canada, ON, Jordan
« Reply #2 on: December 13, 2010, 00:00:45 »
Hi Mary, no the strips do not need to be glued, and shouldn't be.  The rubber will probably be very stiff and a bugger to get into the slot.  Best to put the strips in some hot water to soften it up.  I had to reinsert the strips at the back end and the hot water really helped.  Fingers will probably get a little raw depending on how much you have to install.  You can try inserting one end and then sliding it in as you pull it along.  This didn't work for me however, as the screws got in the way.  Good luck.
Cheers
Marcus
Marcus
66 230SL  Euro 4 speed
« Reply #3 on: December 13, 2010, 03:28:19 »
Like Marcus said, they should not be glued and heating them first is a big help.  They need to be cut to size, heated with boiling water or the like and then one side fitted in first (preferably the top) then with a very blunt instrument, like the back end of a small tea spoon, carefully press the lower edge in to the slot.  I used a screwdriver that i had that was very blunt and rounded so that it did not mark or damage the rubber. I think Millers and the Mercedes Centre in CA have the rubber in one long piece that you cut to size
It's a slow and labour intensive job but not necessarily hard if you are using new rubber and warm it first.
« Last Edit: December 13, 2010, 03:30:52 by Garry »
Re: Rubber stripping on middle of side doors for ding protection
« Reply #4 on: July 09, 2015, 05:31:38 »
I am reviving this topic because I need to install new strips and want to cut them correctly.
Should the ends of these rubber strips be cut at an angle or straight?
I have read somewhere that only the ends at the fender lips should be be angled but those in the center should be straight as shown in the photo.
Is that correct? Who knows the answer?
« Last Edit: July 09, 2015, 05:37:40 by 66andBlue »
49er
  • USA, CA, El Dorado Hills
« Reply #5 on: July 09, 2015, 14:43:30 »
Hello Alfred, Here are pictures of mine. They are original.
1969 280SL 003820
4 speed manual, PS. 77K+miles
« Reply #6 on: July 09, 2015, 16:05:59 »
Thanks John!
Please help me with orientation; are we looking at the strips on the driver site only?
« Reply #7 on: July 09, 2015, 16:58:10 »
Alfred, I went to look at the ones on my 280 SL, and very difficult to get a good picture of. They appear to be formed to fit each section and not cut. Perhaps the original ones were a set but the replacement are from roll stock that need to be cut. I am around this week and next if you want to come take a look. Much easier.
49er
« Reply #8 on: July 09, 2015, 19:49:49 »
Thanks John!
Driver's side, front (1st picture) to back (last picture). I can get some close ups later on today.
1969 280SL 003820
« Reply #9 on: July 11, 2015, 05:11:07 »
Yes, the angles vary depending on the location. After cutting I use a bench mounted, cloth buffing wheel  and compound, on the angle cuts to soften the edges, giving it the original molded look.  Alfred, I saved all the original ones off your 230SL, so you could have a pattern for cutting the new ones.
« Reply #10 on: July 11, 2015, 05:46:46 »
Thanks Joe!
Since I do not have a cloth buffing wheel here I experimented with a heat gun and it seems to work also.
When the ends started to melt or kind of glace over I used my finger (wearing blue nitrile gloves) and smoothed the edges.
Here is a photo of my test piece.
TJMart
  • USA, NC, Matthews
« Reply #11 on: July 11, 2015, 19:26:55 »
I installed mine a few years back and remember to cut it a bit longer and compress the rubber as much as possible when installing it to prevent the rubber from shrinking with age and leaving a gap.
Good luck!
Tony
Tony
1970 280SL, 4 Speed
RobSirg
« Reply #12 on: July 11, 2015, 23:34:18 »
Tony/Joe/Alfred,
Some great ideas here - I'll be sure to save this page when I get around to this job - one of the few enjoyable tasks I can do myself.
Interesting about the shrinkage with age - I was almost certain the strips on my blue car are original ( they are hard as a rock) but they are a little short all around. That might explain it.
Thanks again
Rob
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
