Become a
Full Member
Emergency Contact List
General Discussion
removal of the round steering wheel pad
Topic: removal of the round steering wheel pad (Read 3588 times)
ljg
November 09, 2010, 21:53:11 »
The center pad on the steering wheel seems to be held in place by three clips. What is the best way to remove this pad without damaging it.
ljg
Full Member
Platinum
USA, CA, Solana Beach
Re: removal of the round steering wheel pad
November 09, 2010, 22:16:56 »
As the Technical Manual recommends: "The hub pad is fixed to the wheel by three hollow plastic connection sleeves. Grab the perimeter of hub pad with both hands and pull it off the hub. Sometimes it may be necessary to use a blunt piece of wood and pry the pad away from the signal hub."
http://www.sl113.org/wiki/uploads/Interior/HubPad1.jpg
1966 230SL automatic 334G light blue (
sold
ljg
Reply #2 on:
November 10, 2010, 00:35:14 »
Thanks very much.
ljg
scoot
Full Member
Platinum
USA, CA, Altadena
Reply #3 on:
November 10, 2010, 17:35:56 »
The white plastic connecting sleeves loose some of their tooth after repeated use (extraction of pad) and can be replaced. I think it's a real cheap part to buy.
Scott Allen
'67 250 SL (early)
Altadena, California
General Discussion
