Author Topic: 5 speed ZF Pagoda, how do you tell it is from the data card??  (Read 13149 times)
Drewtee
  • England, Kent, Sevenoaks
I've been sent a data card on a car which is supposed to have a 5 speed ZF box in it but i cannot see any codes on the card which confirm the different axle and the ZF box. How do you confirm it is a true Pagoda 5 speed from the data card?
Andy Tee
Rhd 5 speed 728h with parchment interior
LHD Brabus - 4 speed , soon to be 5 speed.
W111 3.5 Cab and Coupe both RHD
Re: 5 speed ZF Pagoda, how do you tell it is from the data card??
« Reply #1 on: August 20, 2010, 22:58:05 »
Andy,
Go into the Technical Manual and look under Data Cards and then Codes. You can see the different Data Cards depending on what year it is.
Try
http://www.sl113.org/wiki/DataCard/OptionCodes
The 5 speed will be code 230 unless a late model 280 from 1.4.1970 was option code 429 as you probably have seen in Alfred's post yesterday.
JimVillers
  • USA, VA, Virginia Beach
« Reply #2 on: August 20, 2010, 23:03:15 »
The 230 code is in the "wenig gewuscht" box
Jim Villers
« Reply #3 on: August 21, 2010, 00:41:49 »
Here is a data card from a 280sl '69 RHD and as you see Jims as a 230SL there are slightly differences in layout.  The Tech Manual will give you all the different Data cards to year.
Drewtee
« Reply #4 on: August 21, 2010, 06:38:15 »
As i thought. I had already checked for the 230/232 codes.
So this data card definately does not represent a 5 speed?
Andy Tee
« Reply #5 on: August 21, 2010, 09:53:19 »
No Cigar,
if you have a 5 speed it looks like it has been modified from the original 4 speed and can I do a deal for you!!! ;D
« Reply #6 on: August 21, 2010, 11:02:17 »
Well, it does have a chassis # > 017927 and a 429 code....
See Arjun's post
http://www.sl113.org/forums/index.php?topic=13295.0
« Last Edit: August 21, 2010, 11:04:25 by naj »
Drewtee
« Reply #7 on: August 21, 2010, 12:05:29 »
Ok, so it  looks  like the tech manual does need an update
Andy Tee
« Reply #8 on: August 21, 2010, 13:06:10 »
Andy,
Am a bit confused by Naj's post.  Your car is not the same one talked about by Aashish?
You have a chassis number >017927 but no 5 speed code of 429?
Drewtee
« Reply #9 on: August 21, 2010, 13:19:03 »
No, i think it is different. The car i am looking at is a UK car and Aashish is in the US. I attached the data card on my previous post and it has code 429 on it. If Aashish could confirm his VIN number or post his data card we can confirm it is not the same car.
Andy Tee
« Reply #10 on: August 21, 2010, 13:22:10 »
I cannot see where the 429 is on the data card?
there is the axle code 212  and the black hard top code 740 in the options area.
Drewtee
« Reply #11 on: August 21, 2010, 13:32:16 »
top right, second box in?
Andy Tee
« Reply #12 on: August 21, 2010, 13:50:12 »
Now I see what Naj is talking about, the 422 or 426  and the 429 of yours.  Not the normal area where the optional 5 speed was listed.  Will be interesting to see if Aashish's data card is the same and the Tech manual needing changes.
Maybe you do have the holy grail as well as getting a cigar.
Drewtee
« Reply #13 on: August 21, 2010, 14:03:31 »
no holy grail yet, i'll be seeing it in the flesh next w- end. Will take a few pics whe i'm there.
Andy Tee
jaymanek
« Reply #14 on: August 22, 2010, 10:04:56 »
Its not a 280 in Silver with Red Leather? If so I went to see this car a few months back...
Thought id ask as there cant be many 5 speeds for sale in the UK.
If it is the above car, I can give you the run down on the car... Im on my mobile anytime which is on my website www.mercland.com
Drewtee
« Reply #15 on: August 22, 2010, 10:51:25 »
Thanks for the heads up Jay
Andy Tee
Drewtee
« Reply #16 on: August 24, 2010, 08:01:04 »
is the gearbox seriel number easily accessible or only if you take it apart!!
Andy Tee
jaymanek
« Reply #17 on: September 10, 2010, 20:13:53 »
Did you buy the car? It says sold on the advert now so must be you?!
Drewtee
« Reply #18 on: September 11, 2010, 06:41:07 »
Yes, I ended up getting it.
It has a few issues cosmetically which I will sort out, but in no rush. I may well  bring it back to it's original external/ internal spec in a year or two so gently getting idea on costs from different sources.
I absolutely love the drive. Very different feel to the auto car (obviously!) but equally enjoyable in a very different way ( if that makes sense- it's a little early)
Andy Tee
jaymanek
« Reply #19 on: September 14, 2010, 19:33:19 »
Yes that car drives fantastic...
I wish my car had power steering as i remember driving that car felt effortless whereas with mine it feels like a bit of a workout around town!
