Author Topic: Whats this for? "A" Pillar Clips  (Read 8139 times)
gnj588d
« on: July 21, 2010, 18:27:04 »
there is a small chrome clip type thing at the top of the window rubber nearest the windscreen it  slides into the metal channel that hold the door seal,it seems to act as a support for the rubber when you close the door.mine has only got one on the drivers side {RHD} should they be on both sides
« Last Edit: July 27, 2010, 12:33:31 by 280SL71 »
Re: Whats this for?
« Reply #1 on: July 21, 2010, 19:49:03 »
Do you mean the clips shown in the photo?
They are on both windows.
Larry & Norma
Re: Whats this for?
« Reply #2 on: July 21, 2010, 19:51:38 »
Do you have a photo of these in situ, I don't recognise these pieces so maybe mine are missing :o
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
gnj588d
Re: Whats this for?
« Reply #3 on: July 21, 2010, 19:55:20 »
Yes thats them .Mike
Re: Whats this for?
« Reply #4 on: July 22, 2010, 00:58:09 »
According to the 250SL/280SL parts list the  p/n for these angle clips is 1137250141 and it shows a location on the A-pillar (Group 72). It is still available - although the price will make you sick!
However, these clips were also on the 230SL/early 250SL but the exact location is not so clear. On my 230SL they are located at the bottom end of the A-pillar and I believe there is also one on the hardtop at the same location above on the horizontal rubber seal. Since the hardtop is currently in storage I cannot check it.
My (non-original) 280SL has four of these clips on the hardtop but none on the A-pillar. See attached photos.
This makes some sense since the molding on the A-pillar of the 280SL is quite different compared to the one on the 230SL.
I hope John L. can post photos of his original 250SL showing these clips.
Re: Whats this for?
« Reply #5 on: July 22, 2010, 01:15:30 »
Half the group have run out to their cars to check if they have them.  I don't and it is something that I have missed when doing the rebuild of the hard top.  I don't understand where they go on the A pillar?
Re: Whats this for?
« Reply #6 on: July 22, 2010, 01:32:20 »
Hi Garry,
I agree that on a 280SL I cannot see where they should go on the A-pillar.
Whereas on the 230SL - as you can see in my photo - it makes sense. Or not?  ???
I looked around on Brian Peters' web site (MotoringInvestments.com) and found photos of 280SL hard tops and they do have two clips on the horizontal rubber seal. In addition there is a photo of a 230SL that has the clip on the A-pillar.  Unfortunately no photos of a 230SL/early 250SL hard top.
« Last Edit: July 22, 2010, 03:22:06 by 66andBlue »
gnj588d
Re: Whats this for?
« Reply #7 on: July 22, 2010, 20:21:05 »
Thanks for the info and photos I am sorted know,I did feel a bit fiant when I rang for the part off M.B. £25 each. oh dear?.Thanks again eveyone Cheers Mike
Re: Whats this for?
« Reply #8 on: July 23, 2010, 05:34:27 »
Hi Alfred,
Thanks, can see where they would go on the hard top but the door A pillar does not make sense so will not worry about it.  Will have to watch out for some next time I am at my favourite wreckers.
