Please check out joining the
Emergency Contact List
for help during your travels!
Body, interior, paint, chrome, and cosmetic items
soft top adjustments
Topic: soft top adjustments (Read 4062 times)
gnj588d
July 18, 2010, 12:23:55 »
Is it normal to have to use 14mm of shims under the plates in the soft top compartment to get the seals around the window to fit properly,I have tried other ways with no luck. Thanks Mike.
Larry & Norma
Full Member
Platinum
United Kingdom, England, Southampton
Re: soft top adjustments
July 18, 2010, 16:45:12 »
Can you still fit the rear centre catch on the raised softtop with that much packing?
Any photo's?
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
gnj588d
Reply #2 on:
July 19, 2010, 09:37:11 »
The back does click in quite easy,the shims are 12 mm not 14 as I reported before will try to send photos later .Cheers Mike.
gnj588d
Reply #3 on:
July 21, 2010, 18:13:02 »
Thank for the info but I finally got the seals fitting snug with just about 3mm of shims after a lot of fiddling and cursing.Cheers Mike.
