Author Topic: Sway Bar Bush replacement  (Read 3581 times)
« on: March 07, 2004, 06:00:52 »
Hey group,
I have a new swaybar bush kit.
My question....
Is it just a simple matter of unbolting everything from the sway bar, giving everything a clean and replacing the bushes and bolts and tightening up?
Should this be done on level ground?
Do I need to have a wheel alignment done?
Bob (Brisbane,Australia)
early 250 SL, RHD
Re: Sway Bar Bush replacement
« Reply #1 on: March 07, 2004, 07:58:19 »
I did this some time ago. I replaced the rubber bushings (both at the swaybar ends and where the swaybar clamps onto the car frame) with polyurethane bushings from Cox Racing. These bushings turned out to be thicker than the originals for the swaybar ends. So I modified (shortened) the metal spacer tubing somewhat (you'll see what I mean when you take up the job). When you remove the swaybar from the frame, you need to take care to mark the exact positioning on the frame, since there is an adjustment to the geometry there. The whole job is very easy and quick.
I decided to get a four-wheel alignment done afterwards, because I was not certain whether I had made the modification correctly or upset the geometry. These alignments are not very expensive, and if you don't know when it's been done the last time, I would definitely have it done. Do try to get a place that is experienced with older cars and has the correct specifications.
« Reply #2 on: March 08, 2004, 04:01:52 »
"Sway Bar Bush replacement"
Sorry, I thought Kerry was the nomination to run against Bush  ;)
(sorry, couldn't resist)
« Last Edit: March 08, 2004, 04:02:22 by Tosh »
