Author Topic: Head bolts  (Read 4978 times)
declanobrien
Head bolts
« on: April 01, 2010, 20:11:18 »
Reading the service manual for my 280 SL 1970, it notes "replace the 10k bolts with 12k". Can anybody explain what this means? Also, the bores are at the max at 87.5mm, meaning the engine has already been worked on. If I find that they are worn,can I sleeve the 280SL bores, and reuse my 87.47 pistons?
Thanks for any help.
Declan
drmb
Re: Head bolts
« Reply #1 on: April 01, 2010, 20:59:59 »
Mahle Germany now make 87.97 pistons as a special repair size 3
Mercedes Restorer ( retired )
1996 E320 Cabrio
1967 Morris Cooper
Lloydmarx@xtra.co.nz
RickM
Re: Head bolts
« Reply #2 on: April 01, 2010, 21:15:02 »
Declan
Hi Declan:
This should explain sufficiently...
declanobrien
Re: Head bolts
« Reply #3 on: April 02, 2010, 18:42:06 »
Many thanks. Very helpful to know that further oversize pistons are available. As regards the bolts, as I do not know how many times they have been reused, would it be safer to replace when I rebuild the engine?
RickM
Re: Head bolts
« Reply #4 on: April 02, 2010, 21:23:15 »
Have the bolts been upgraded to the recommended 12K (Marked 12L on the head)?
declanobrien
Re: Head bolts
« Reply #5 on: April 04, 2010, 12:06:30 »
Checked the bolts, and they are 12's.
Declan
