Author Topic: UK Speedometer repair  (Read 5184 times)
CharlieSierra
  • United Kingdom, England, Flimwell, Wadhurst, East Sussex
« on: February 20, 2010, 20:30:45 »
Are there any UK members that can recommend a local or european speedometer repair shop?
Charles
jameshoward
Re: UK Speedometer repair
« Reply #1 on: February 20, 2010, 22:45:42 »
What's wrong with your speedo?
James Howard
1966 LHD 230SL
CharlieSierra
« Reply #2 on: February 21, 2010, 19:32:33 »
There is a terrible screaming noise from it whilst driving. I have oiled the speedo drive cable but this hasn't improved the situation...
jameshoward
« Reply #3 on: February 21, 2010, 20:51:28 »
I have an intermittent problem whereby the thing screams at me from time to time. Did it twice yesterday, but hasn't done it for over 12 months before. I suspect lack of use has something to do with it.
A reputable gentlemen and expert in these matters advised a course of action that involves removing the inner flex shaft, cleaning, soaking in ATF, cleaning again, re-soaking in ATF then reinstalling. (ATF has some quite aggressive cleaning properties).
I will give this a try before I try to pull the speedo. The lacerations from a failed (5 hour) effort at replacing a tacho for a friend have only just healed, but the mental scars run deep.
JH
James Howard
1966 LHD 230SL
CharlieSierra
« Reply #4 on: February 21, 2010, 21:20:20 »
Sounds like a sensible place to start. I'll have a go next weekend, thanks.
Charles
