Author Topic: Steering wheel Color?  (Read 15868 times)
717-113
« on: February 16, 2010, 08:43:35 »
I was about to repaint my steering wheel but need to pick a color. I couldn't find anything in the manual, or on the boards about what color it should be. I'm assuming the steering wheel should match the shift knob, is this correct? unfortunately my shift knob is wood so that's no help, I plan to replace it as soon as I pick a color. How can I tell if I should go with White or Black? Thanks
Jordan
  • Canada, ON, Jordan
Re: Steering wheel Color?
« Reply #1 on: February 16, 2010, 12:34:30 »
Someone please correct me if I am wrong but I believe the steering wheel, shift knob and the knob at the end of the parking brake were standard black (plastic) for all cars, regardless of colour of the car.  White was on option.   There were no other colours.  I don't think wood was ever an option. :(
Marcus
66 230SL  Euro 4 speed
mbzse
« Reply #2 on: February 16, 2010, 13:36:22 »
Black was standard, yes. White steering wheel could be chosen and fitted when you put in an order for a new M-B.
There was no added cost for this option. Noted in the data card with SA 55/1
.../... I believe the steering wheel, shift knob and the knob at the end of the parking brake were standard black (plastic) for all cars, regardless of colour of the car.  White was on option.   There were no other colours.  I don't think wood was ever an option. :(
/Hans S
717-113
« Reply #3 on: February 17, 2010, 04:20:19 »
by 55 are your refering to whats circled in green on this data card? on mine its just a "-" but theres a "1" in 67, any idea what that means? Thanks
« Reply #4 on: February 17, 2010, 05:16:03 »
67/1 (=617) means "Special lights mandated in Italy".
Most of the codes are listed in the Technical Manual: http://www.sl113.org/wiki/DataCard/OptionCodes
Looks like to you have a car that was sold in Italy, check your Body and Paint Number Plate:
http://www.sl113.org/wiki/DataCard/DealerandCountryCodes
« Last Edit: February 17, 2010, 05:55:29 by 66andBlue »
717-113
« Reply #5 on: February 17, 2010, 05:39:42 »
ahh, I never knew that till now thanks. But shouldn't 67/1 = 671 = no varta battery?
« Reply #6 on: February 17, 2010, 05:48:30 »
Oops .. 617..  671 .. dyslexia caught up with me again!
mbzse
« Reply #7 on: February 17, 2010, 10:42:43 »
Yes, just so.  55/- tells that the car was delivered from M-B production with a black steering wheel
Really a lot was documented about each car made - and all info is still kept in the factory archives...
Sometimes I tell people (keeping my face straight) "in box 68 the code number indicates what was served in the factory canteen on that day"
 :D
Quote from: 717-113
« Last Edit: February 18, 2010, 18:40:52 by mbzse »
/Hans S
717-113
« Reply #8 on: February 18, 2010, 07:06:49 »
Perfect. Thanks for you help.
Does anyone happen to know the color code for the black? or any brands and colors of paint that would be good to use to re-paint the wheel?
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #9 on: February 18, 2010, 23:28:00 »
My car has a white steering wheel and a black shift knob. box 55 on my data card has a -.  I don't think anyone changed the steering wheel.  Is it possible that a different box would have the info.  There are several shown with numbers in them.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
717-113
« Reply #10 on: February 19, 2010, 03:25:53 »
from my understanding, that center cap should match the wheel color. So if the center cap is org. then the wheel should be black?
mbzse
« Reply #11 on: February 19, 2010, 12:53:09 »
In the 40 odd years that passed, yes, some PO exchanged your steering wheel to a white one :)
Quote from: badali
/Hans S
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #12 on: February 19, 2010, 18:19:37 »
Thanks,  I'll only change it if I find a nice used one.  At the price of new ones I can live with it.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2025 E53 AMG Sedan
IXLR8
« Reply #13 on: February 21, 2010, 14:35:40 »
Hi--
Is there a color code for the black and the white steering wheels?
For example, same as light ivory, or parchment white, or??
Joe
IXLR8
« Reply #14 on: February 27, 2010, 00:34:15 »
Hi--
Does anyone have a clue about color codes for black and white steering wheels and shift knobs?
For anyone who has painted a steering wheel--white or black--
Which color white or black did you use? Are you satisfoied with how the color ended up?
What type of paint did you use--Epoxy?, Enamel?, Acrylic?, Base color and Clearcoat?
Thanks in advance for your help.
Joe
Silicon Valley Brian
  • USA, CA, Santa Clara
  • American splitting time between USA and NL
« Reply #15 on: March 18, 2013, 23:08:26 »
Brad, I'm not so sure your steering wheel was replaced. My 1967 230 is a U.S. spec car that also has a white steering wheel and a black auto shift knob. We bought the car in 1970 from the original owner, and it is doubtful he would have had any reason to change the steering wheel.  That said, my mechanic here in the Netherlands says most W113s have matching steering wheels and shift knobs.
Brian Akre
1967 230 SL, U.S. spec, 050 White, Black top, 116 Kaviar interior, #17,030 of 48,912;
1997 SL 500 Sport, U.S. spec, 269 Tourmaline Green, Parchment interior, #145,506 of 204,940;
1991 Nissan Figaro, Emerald Green, #15,717 of 20,073;
2023 Volvo S60 Recharge (hybrid), Black, daily driver
Jack Jones
  • Canada, ON, Milton
« Reply #16 on: March 19, 2013, 02:27:37 »
Does anyone have a dark exterior coloured car with cognac interior and an ivory steering wheel. I am tempted to go that way and would like to see a photo please.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
Hans2012
  • USA, TX, Houston
« Reply #17 on: March 19, 2013, 03:29:09 »
Please see the attached - this is a car marketed some time ago by Hatch & Sons.
1971 280 SL - 268 Dark Green - Cognac Leather
« Reply #18 on: March 19, 2013, 08:44:16 »
Here is another one of interior of Dark Olive but not cognac but light yellow.
Jack Jones
« Reply #19 on: March 21, 2013, 04:06:06 »
Thank-you for the great pics and based on these I will follow through with the ivory wheel.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
pj
  • Canada, ON, London, Ontario
  • 1965 230SL
    • my home page
« Reply #20 on: March 21, 2013, 05:04:40 »
Hello Jack,
are you saying that you plan to acquire a white steering wheel? Let me know how or where. I like them, too.
Peter J
1965 230SL #09474 named Dagny
2025 GLC300 coupe named Rigel
KevinC
« Reply #21 on: March 21, 2013, 16:48:09 »
I don't believe that original steering wheels were "painted" but a solid material with color throughout; but I would guess like anything, they could be painted or refinished of done correctly for the material they are made from. Now 47 years old, I would describe the color as 'Piano Key Ivory"
