Author Topic: Linkage wear  (Read 6044 times)
230slhouston
  • USA, TX, Houston
Linkage wear
« on: January 27, 2010, 02:29:47 »
Hi all,
How much of play/wear should the accelerator linkages have? My car is an automatic. I set my idle to a respectable 750RPM, when I engage drive or reverse, the idle solenoid (not sure what it is called), travels forward but not far enough to maintain the idle. The idle drops to 400 to 500RPM Even adjusting the little nut to the end of its travel does not make a difference. The solenoid travel moves enough to only move the linkages and take up the excessive play.
Maistran.
Re: Linkage wear
« Reply #1 on: January 28, 2010, 00:21:20 »
If your linkage has any play at all you should consider replacing the brass bushings on the cross shaft and all ball and sockets.   Search under linkage adjustments for more information
Re: Linkage wear
« Reply #2 on: January 28, 2010, 00:25:44 »
How much "play" is within spec?
I replaced my brass bushings and still have a bit of side-to-side "play" in the cross linkage.
Guessing...  about 1/4 inch play...
Thanks!
Dave Gallon
  • USA, NC, Statesville
Re: Linkage wear
« Reply #3 on: January 28, 2010, 08:59:01 »
It sounds like the solenoid simply is not able to over come the return springs if it only moves the linkage enough to take up the slack in the linkage. If the solenoid is operating correctly, it will move its armature to the limit of its travel. Try pulling out the armature by hand to see if it advances the linkage further than when electrically activated. Also, try pulling out the armature when the solenoid is electrically activated. My guess is you will find that
the solenoid has enough travel to raise the idle speed but if not then there is a linkage wear or adjustment problem. If the solenoid armature can be pulled out enough to advance the linkage, put a voltmeter between its screw terminal and ground. Measure the voltage available when in reverse and when in one of the forward gear positions. You could also try jumping +12V directly to the solenoid to see if the armature moves out enough to keep the idle speed where it belongs. If a good source of +12V (via a jumper) will not advance the solenoid adequately than the solenoid itself is weak. If +12V does advance the solenoid but the available voltage at the solenoid is appreciably under +12V when being supplied by the pressure switches on the transmission, than one or both of the pressure switches is bad. There is a separate pressure switch for reverse and for the forward gears so if the system works well in one but not the other transmission position, the corresponding pressure switch is bad. Of course, it is wise to also check for damaged wring. If memory serves, the idle is specified to not drop more than 50 RPM when the transmission is moved from P or N to one of the drive positions and this is how I used to adjust my car. Unfortunately, these parts have become very expensive. The transmission pressure switches are 001 542 13 17, current US list $162, my price $119.36. The constant speed solenoid is a 000 072 05 00, current US list $398.00, my price $292.86.
Dave Gallon
Gallon Restorations
113.044-12-001155
230slhouston
  • USA, TX, Houston
Re: Linkage wear
« Reply #4 on: January 29, 2010, 03:19:55 »
Thanks everyone. All of you are amazing.
I will tinker a little this weekend and reach out for more help.
Maistran
Re: Linkage wear
« Reply #5 on: January 29, 2010, 15:41:42 »
I had the same lateral play in the cross shaft and installed a spring to keep tension on the passenger side end.  I posted a picture on this site but can't find it right now.  I think Andy Wolff did something similar
awolff280sl
  • USA, FL, Sarasota
Re: Linkage wear
« Reply #6 on: January 29, 2010, 18:23:52 »
While the spring is a more elegant solution, it does require removal off the cross-over linkage. A quicker solution is to wrap a hose clamp around the cross-over linkage and abut it against the tower that that holds the cross-over linkage to eliminate lateral movement of the cross-over bar.
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
