Author Topic: What's in Your Injection Pump?  (Read 5705 times)
ctaylor738
  • USA, VA, Falls Church
« on: December 03, 2009, 16:15:28 »
I was living with my run-lean-on-warmup problem until Gernold adjusted my linkage to eliminate the early movement of the pump lever.   After that, the start-die and driving while warming up got much worse as in terrible.  The problem is that the pump just wouldn't deliver enrichment with a cold engine, despite the air part of the WRD working properly.
So, I talked to Hans at H&R injection about rebuild prices.  I described the problem, and he asked me if I had checked the oil in the pump.  I said, no, I thought it was fed off the line from the engine and there was nothing to check.  He explained where the dipstick was.  He said the oil needs to be checked and changed periodically.  He wanted me to look for gas in the pump's oil, which would indicate worn seals and the need for a rebuild.
I did a search on this and found an excellent post by Arthur and others.  Arthur explains that on the 230 and 250 pumps, the oil from the engine lubricates the shaft seal, and that the pump has it's own little sump.
http://www.sl113.org/forums/index.php?topic=4199.0
So I found the dipstick, a 14mm head with a screw notch just under and to the outside of the solenoid.  As soon as I removed it, dirty oil started gushing out into the pan I put under the car just in case.  Then I used a tube from a Windex bottle and my MityVac to suck out the rest.  There was 3-4 times as much oil as should have been there.
The good news was that it did not smell of gas, it was more like really dirty engine oil.
This morning I refilled with about 175 ml of 10/30. Things aren't perfect, but much better.  The car was quite driveable warming up, smoother and more responsive.  Apparently, excessive oil impedes the flywheights and generally screws up the internal working of the pump.
Maybe I am the only one who didn't know about this aspect of the pump, but thought I would post it anyway.
« Last Edit: December 03, 2009, 16:33:13 by ctaylor738 »
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
xcashewx
Re: What's in Your Injection Pump?
« Reply #1 on: December 08, 2009, 03:06:31 »
reading this made me change mine as well.
i checked the oil level and it was way above the mark, but the oil was still honey colored. that didnt seem right so i used the windex pump and soon discovered excess amounts of nasty black slude soon came out.
i think this procedure is highly overlooked as i dont think mine has been changed in forever
BMWTom
« Reply #2 on: December 23, 2009, 05:52:46 »
Thanks for the post. I am still working through the fuel system on my 250SL and was wondering where the dipstick was on the injection pump. I fear what will come out!
Largeowner
« Reply #3 on: December 28, 2009, 04:05:40 »
When I first purchased my 230 SL I had a strange problem.  When the gas tank reached half full (or empty if you have a negative personality), the engine would stutter, miss, and stall.  Put a bit of gas in the tank, and the problem would disappear again.
When I drained the old,very dirty oil out of the Injection Pump, the problem went away!  Now, I change the pump oil whenever I change the engine oil.
Large
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #4 on: December 29, 2009, 18:25:28 »
BMW Tom,
The dipstick is only on the early model pumps.  The later models are lubricated with engine oil.  I believe this includes yours.
