Become a
Full Member
Emergency Contact List
Body, interior, paint, chrome, and cosmetic items
Solenoid Rubber Spacers - still available?
Topic: Solenoid Rubber Spacers - still available? (Read 5315 times)
dtuttle123
November 26, 2009, 14:46:27 »
Are these rubber spacers for the solenoids still available - or could I find something like this at the hardware store?
Last Edit: November 27, 2009, 10:06:52 by 280SL71
w113dude
Re: Soleinoid Rubber Spacers - still available?
November 26, 2009, 20:58:49 »
I don't know if they are, but a quick trip to your local hardware store you can pickup 4 faucet washer for $.35 each, cheap alternative.
zoegrlh
Full Member
Gold
USA, VA, Williamsburg
Beauty from top BCW
Reply #2 on:
November 27, 2009, 06:50:52 »
Answer to your question, no they are not available any longer from Bosch. I tried to find new ones a few years ago. You need to find a 111 or 112 sedan and take off the regulators, you will see that they have the same rubber spacers, but rubber might be cracked.
Robert Hyatt
Williamsburg, VA.
zoegrlh
Full Member
Gold
Beauty from top BCW
Reply #3 on:
November 27, 2009, 06:52:13 »
Answer to your question, no they are not available any longer from Bosch. I tried to find new ones a few years ago. You need to find a 111 or 112 sedan and take off the regulators, you will see that they have the same rubber spacers, but rubber might be cracked. Yoiu may want to just buy new regulators that will come with spacers.
Robert Hyatt
Williamsburg, VA.
Inactive
Platinum
United Kingdom, Surrey, New Malden
Reply #4 on:
November 27, 2009, 09:18:20 »
There are these from Finland. They are for a GM application so may be available in the US.
Somewhat bigger than originals.
http://www.nippelit.fi/1st/html/default.asp?id=9188&p_id=8945&editmode=showprod
Full Member
Platinum
USA, OH, Blacklick
Re: Solenoid Rubber Spacers - still available?
Reply #5 on:
November 27, 2009, 14:55:12 »
This type of relay was used on many many MB sedans up into the mid 70s. You should be able to find some nice used ones from almost any W108, W114, W111, W112, MB sedan of that era. Hopefully you have access to some donor cars.
gzmavian
Reply #6 on:
November 27, 2009, 18:16:56 »
I just made a couple of these last month for my 280SL. I found rubber grommets at either Home Depot or Lowes ( can't remember for certain) and removed the old cracked rubber and replaced the two new black rubber gommets over the original brass sleeve. Looks as good as the original and cost about a buck. Good luck. Greg
dtuttle123
Reply #7 on:
November 28, 2009, 11:55:37 »
Thanks everyone for the responses & advice!
