Author Topic: driver side mirror rebuild  (Read 4072 times)
wrayb
« on: November 10, 2009, 15:55:53 »
anyone have any tips on replacing the glass in the drivers side door side mirror. I have new plastic gasket etc but am unable to get the whole thing seated properly.
Wray Brady
w113dude
Re: driver side mirror rebuild
« Reply #1 on: November 10, 2009, 16:59:11 »
The mirror glass is pushed against the frame with a spring, don't be afraid you won't brake any thing, by pushing the glass mirror in you should be able to twist it on angle ant get the mirror and the plastic frame out, 5 min, job.
wrayb
« Reply #2 on: November 10, 2009, 19:22:38 »
I'm having trouble putting the thing back together.
w113dude
« Reply #3 on: November 10, 2009, 22:41:24 »
It's a little tricky, you have to hold the mirror glass in place with one hand & try to place the plastic retainer with the other while pushing back the mirror. Make sure you put back the piece of paper behind your new mirror, otherwise the silver lining will get damaged from vibration.
