Author Topic: Spanner/Adaptor #111589020700 to remove differential pinion nut  (Read 4800 times)
Bahama
This part number is no longer valid, how do I find the Spanner/Adaptor to work on my 250sl Dif?
Bahama
Re: Spanner/Adaptor #111589020700 to remove differential pinion nut
« Reply #1 on: July 14, 2009, 16:18:24 »
You need a pin wrench, available from Samstag: http://www.samstagsales.com/mercedes.htm
(this is the one you need: http://www.samstagsales.com/SirTool/stm_0030.jpg)
I've previously posted the dimensions and a little tool I made here: http://www.sl113.org/forums/index.php?topic=3761.msg22817#msg22817
230slhouston
  • USA, TX, Houston
« Reply #2 on: July 15, 2009, 03:51:40 »
If you are handy, you can buy a socket and grind it to fit. I did mine recently, cost me all of $4 and twenty minutes to measure and grind it.
Cheers
Miastran
