Author Topic: Injection pump oil valve  (Read 5061 times)
Miloslav Maun
  • Czech Republic, Praha, Prague
  • 1966 230 SL
    • http://www.pagoda.un.cz
« on: July 13, 2009, 16:24:56 »
What is the function of the pressure valve on the back of the injection pump? I cannot blow through it any direction. Is that normal?
Thanks.
BTW: The car is a 230 SL with the pump that has its own oil dipstick.
Re: Injection pump oil valve
« Reply #1 on: July 13, 2009, 20:11:42 »
That thing is a one way check valve. It lets oil into the pump to lube the elements but won't let oil mixed with gas go back into the oil galley.
Normally the engine will have enough oil pressure at idle to hold a constant pressure and keep oil pressure around the valve elements. If the pressure drops very low the valve will close preventing fuel from backing up into the engine oil.
 There's a cone shaped valve similar to what's used in the CSV with a small spring behind it. If this gets stuck or seized no oil will flow into the pump and it will seize too or damage the injection elements. You can take the check valve apart and clean it. You should be able to push the valve open with very little force. I think it's less than 10 PSI.
Miloslav Maun
  • 1966 230 SL
« Reply #2 on: July 14, 2009, 20:48:35 »
Thanks. Fixed.   :)
« Reply #3 on: July 15, 2009, 01:02:26 »
That's good. It's something that HAS to work right or the pump will be ruined.
« Reply #4 on: July 15, 2009, 06:46:15 »
Thanks. Fixed.   :)
Muf,
Did you take any pictures?
