with our official
Pagoda SL Group logo
from our official partner.
Electrical and Instruments
? sticking ignition relay
Topic: ? sticking ignition relay (Read 4381 times)
auret
May 26, 2009, 05:09:58 »
My 1970 280sl continued to run today when I turned off my car and removed the key. This was not pre-ignition as it ran perfectly smoothly. It switched itself off after about one minute. This happened again later in the day. Is this caused by a sticking ignition relay and where is it situated? I would appreciate any help. Thanks.
Associate Member
Platinum
Canada, ON, Port Lambton
Re: ? sticking ignition relay
May 27, 2009, 14:19:23 »
Ohhhhh....... that's not good.
I don't think there's any kind of relay and it's all in the ignition switch. You need a new one because it should shut off every time. You will need to pull all the gages to get at it.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
auret
Reply #2 on:
May 28, 2009, 15:47:58 »
Thanks for the news. I don't have the time or energy for that now. Just completed the rear axle rebuild. Sounds like a good winter project. Probably pull the whole dash, recover, refinish the wood and rebuild the rheostat at the same time.
