Author Topic: why does the lighter socket not work with modern chargers?  (Read 5405 times)
erickmarciano
  • Canada, Quebec, montreal
I can get my phone charger or GPS to stay on when pluged in the lighter socket .the male part always pops out .
thanks
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: why does the lighter socket not work with modern chargers?
« Reply #1 on: May 23, 2009, 21:10:21 »
The early European cars used a different standard for their lighter sockets.
Here are the sizes
12 volt cigar lighter receptacle and plug, size A
Receptacle inside diameter: 20.93 mm to 21.01 mm (median 20.97 mm)
Plug body diameter: 20.73 mm to 20.88 mm (median 20.805 mm)
Most often used in American automobiles.
12 volt cigar lighter receptacle and plug, size B
Receptacle inside diameter: 21.41 mm to 21.51 mm (median 21.455 mm)
Plug body diameter: 21.13 mm to 21.33 mm (median 21.18 mm)
Most often used in European automobiles, and sometimes as a second socket in American automobiles expressly for DC power connections.
Saab used to make a slip on adapter years ago but I have not seen one in ages.
« Last Edit: May 23, 2009, 22:57:41 by Shvegel »
erickmarciano
« Reply #2 on: May 24, 2009, 16:26:12 »
my car is a late Euro . where can I find an adaptor?
thanks
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #3 on: May 27, 2009, 14:23:09 »
Buy a road map. It won't pop out of your dash.
scoot
  • USA, CA, Altadena
« Reply #4 on: May 27, 2009, 14:54:17 »
I bought a goose-neck map light years ago that fits a cigarette lighter and it came with a plastic sleeve around the "male" end.  That's probably the kind of adaptor you need.  I have no idea where you get one.
Scott Allen
'67 250 SL (early)
Altadena, California
