Author Topic: Need a picture of the Driver side inner fender  (Read 7850 times)
menesesjesse
  • USA, MD, Indian Head
« on: May 04, 2009, 16:58:12 »
I am in the process of completing my motor replacement and I painted the inner fenders without taking a very detailed picture of the drivers inner fender.  I would like a photo of a 1965/1966 automatic 230sl if possible.  I would like to see how all the relays attach properly and what type of fasteners were used.  Thanks in advance.
Jesse
Jesse
1966 Mercedes 230 SL auto
2003 Mercedes E500
1992 Ford F150
1994 Ford Bronco
2019 Shelby GT350R
1967 Mercury Cougar XR7
Re: Need a picture of the Driver side inner fender
« Reply #1 on: May 04, 2009, 18:58:54 »
Here is a shot of my early 250 SL.
menesesjesse
« Reply #2 on: May 05, 2009, 15:52:41 »
Ok this answers some of my questions although I have a small round canister style relay and not 3 square ones on my 230sl.  What type of fasteners are used ? Does someone have a picture from the side of how and what they are mounted with? Thanks for all the help on this.
Jesse
Jesse
2003 Mercedes E500
1992 Ford F150
1994 Ford Bronco
2019 Shelby GT350R
« Reply #3 on: May 05, 2009, 17:05:41 »
Ok, These are the relays on my ex-230.
The dust needs blowing off and I'm not sure the screws are right either.
Part #s for the correct screws:
3x N 007981 003249 1 for wiper relay and 2 for mixture enrichment relay (mounted with rubber buffers)
1x N 000000 000459 Cylindrical relay
Hope this helps
« Last Edit: May 05, 2009, 17:18:08 by naj »
« Reply #4 on: May 06, 2009, 14:49:02 »
Hi Jesse. Here is another for comparison. Cannot say its "original" but its been this way a long time! The larger relays have rubber washers that I recall are hard to find... Wife and daughter are heading to San Fran today with the camera! or I'd shoot a close-up...
menesesjesse
« Reply #5 on: May 06, 2009, 16:13:43 »
Wow I didnt know there was so many combinations here.  Thanks for the photos. Since I only have 3 relays I will follow Naj's picture unless there is some one with a car that is totally original that happens to different.  I am trying to get this car as correct as possible.  Thanks alot for all the help.
Jesse
Jesse
2003 Mercedes E500
1992 Ford F150
1994 Ford Bronco
2019 Shelby GT350R
« Reply #6 on: May 06, 2009, 19:09:09 »
Jesse,
Here's a pic from quite an original car.
« Reply #7 on: May 06, 2009, 23:21:53 »
So, it looks like mine and Naj's last pic are similar -- except I have one more. Guess its time I learn what each one is! Naj can you decipher? I figure a cold start relay, a fuel mixture relay, wiper relay and ????
  • USA, WI, Mequon
« Reply #8 on: May 07, 2009, 00:53:27 »
Not a 230 SL, but early 1967 250 SL.  Might help.
menesesjesse
« Reply #9 on: May 07, 2009, 13:09:11 »
Jesse,
This is a great photo.  Thanks I believe it was painted because my car had a circular area cleaned off for the ground cables.  Thanks for this shot.
« Last Edit: May 10, 2009, 16:06:19 by vanesp »
Jesse
2003 Mercedes E500
1992 Ford F150
1994 Ford Bronco
2019 Shelby GT350R
« Reply #10 on: May 07, 2009, 14:18:01 »
One second relay for CSV, Wiper relay, One of the two rubber mounted relay operates the mixture enrichment solenoid on the FIP while the second one is controlled by the thermo time switch to operate the csv, but Im not sure which is which. If I'm wrong, no doubt somebody will correct
