Please check out joining the
Emergency Contact List
for help during your travels!
Body, interior, paint, chrome, and cosmetic items
Removing the "other" chrome strip....
Topic: Removing the "other" chrome strip.... (Read 6007 times)
Witt
March 24, 2009, 02:47:09 »
Try as I may, I cant figure out how to remove the chrome strip that runs from the rear doorpost all the way to the front in to the foot well on top of the rocker panel. It covers the carpet on the inside and the rubber trim on the out side. ( I am getting the car ready for the paint shop )
I assumed that it would have spring clips holding the trim from the inside ( the trim is U-shaped) over a spot welded body seam. I don't want to use to much force, it is soft and easily deforms.
Any ideas?
CHEERS !
WITT !
psmith
Re: Removing the "other" chrome strip....
March 24, 2009, 05:21:36 »
As I remember, you have to pry the carpet back out from under the strip, which exposes small screws that go down into the rocker panel.
Full Member
Platinum
Australia, Victoria, Kyneton and Brisbane Queensland
Audit Committee
Reply #2 on:
March 24, 2009, 05:43:40 »
I found I also had to remove the kick panels in the foot wells.
1972 MB 280CE W114 Auto RHD 906G
johnd
Reply #3 on:
March 24, 2009, 19:58:58 »
You got good advice above. Expect some screws to be a little rusty, so use a good, sharp screwdriver and lots of downward force on them as you remove. If you look at what that trim strip costs, you'll really be careful with it!
Full Member
Platinum
Audit Committee
Reply #4 on:
March 24, 2009, 22:07:18 »
And if you really mess it up I have two fully reconditioned ones that I would part with. My restoration took so long I forgot that I had already done a set early and did a second set late in the peace.
Witt
Reply #5 on:
March 25, 2009, 03:48:33 »
WOW, I am floored, all that god and speedy advise ! Thanks a million Guys, I'll report back to you soon.
CHEERS !
WITT !
PS: Thank's Garry, that is very kind of you, I keep that in mind !
