Author Topic: ATF Substitutes  (Read 5369 times)
Richard S
  • USA, WA, Anacortes
ATF Substitutes
« on: February 28, 2009, 19:34:41 »
I’m getting ready to change my automatic transmission fluid.  In past years I’ve used Quaker State Dexron II ATF for “Import Vehicles” (#406184), but it is no longer available.  The current ATF nomenclature bears no resemblance to the Dexron II previously recommended to be used in place of the original “Type A” ATF.  So far I’m seeing Dexron VI/Mercon which appears closest to Dexron II.
I’ve read Dr Dan’s input that all ATF’s are probably compatible but that was before the current crop of ATF’s appeared on the market.
My questions are:
1. Is Dexron VI/Mercon an acceptable alternative for our older vehicles?
2. Other than never/never using “Type F” (for Ford products only), are there any other ATF catagories that should be avoided?
Richard
250SL RHD
Midnight Blue
Re: ATF Substitutes
« Reply #1 on: March 01, 2009, 23:51:41 »
Check with The Classic Center to see what they recommend these days. Over the years the factory recommendation has changed numerous times.
Let us know what they say.
Richard S
Re: ATF Substitutes
« Reply #2 on: March 04, 2009, 01:01:54 »
I checked with the Classic Center today about ATF use/compatability.  The feedback was that they recommend any Dexron ATF.  The original Dexron II is no longer available but Dexron VI is the current standard and compatable with all other Dexrons.
Richard
250SL RHD
Midnight Blue
Re: ATF Substitutes
« Reply #3 on: March 04, 2009, 03:27:09 »
Thanks Richard,
That's  what I thought, but it is nice to know for sure.
Joe
