Author Topic: hubcap painting topic, again...............  (Read 10571 times)
john.mancini
  • USA, FL, Nokomis
« on: February 23, 2009, 13:11:30 »
Can anyone recommend a good painter in the New England area who would be willing to paint some hubcaps? I have read all of the past hubcap topics by our members, but I just don't have the patience, or time, to mask off 4 230SL hubcaps. I also can't find the paint (162H, blue/grey). Thanks,
65 230SL 519 Red 4-sp
98 911 cab
56 Ford F100
08 Porsche RS60 Spyder
23 Z4M40i
jsaylor
Re: hubcap painting topic, again...............
« Reply #1 on: February 23, 2009, 18:30:19 »
John,
I have the silicon stencils.  I'd be happy to share them w/ you.  They are for the early smaller hub caps.
jsaylor@aloha.net
john.mancini
  • USA, FL, Nokomis
« Reply #2 on: February 23, 2009, 18:43:52 »
Thank you jsaylor,
I may take you up on that. The other problem I have is finding the 162H in a small spray can. I will let you know. Do the rubber stencils work well? Thank you again.
98 911 cab
56 Ford F100
23 Z4M40i
« Reply #3 on: February 23, 2009, 18:54:07 »
Not to put down an offer of help but if those stencils are the soft rubber type they're not that great to use. They leave a fuzzy line and a PIA to use. You get much better results from fine line tape.
« Reply #4 on: February 23, 2009, 19:14:13 »
Hi John. If you looked over the past posts, you may have seen my experiences. In a nutshell, I tried to tape and paint them myself with very mediocre results. (I know others have done better -- so part of it was me for sure)... I then took them to a local body and paint guy who did them for 30 a piece and he matched the paint to the MB Glasurit code. They look much much better. I suggest you keep searching for a shop you can trust and let a pro do it...
john.mancini
  • USA, FL, Nokomis
« Reply #5 on: February 23, 2009, 20:50:37 »
I think that's my best bet. I know that if I paint them myself they will probably look pretty bad. I'm good at painting flat walls. That's about the extent of my painting ability.
98 911 cab
56 Ford F100
23 Z4M40i
« Reply #6 on: February 24, 2009, 00:18:15 »
Just in case you get to feeling a bit ambitious. www.paintscratch.com offers almost all the paint colors in a rattle can.
I had never done anything like the masking before, but tried one hubcap as a test, and then jumped right in to doing several sets. It took me about 30 minutes to carefully mask off the necessary areas.
rb6667
« Reply #7 on: February 24, 2009, 01:20:33 »
How about the part/stencil  that Mercedes made that allowed you paint the caps on the 280 SL's.   Is this part still available?   I think I  remember seeing one on an earlier post several months ago????
RB6667
sjiatrou
« Reply #8 on: February 24, 2009, 02:04:43 »
I picked up some 050 (white) from Microfinish, it was a perfect match for doing some touchup, I'm waiting for some Astral Silver to shoot the hubcaps for my 450SLC. I'm going to mask/paint these myself. I'll let you know how it comes out.
http://www.automotivetouchup.com/
john.mancini
  • USA, FL, Nokomis
« Reply #9 on: February 25, 2009, 13:49:55 »
For me to do it myself, the problem is finding someone who can get the color 162, blue/grey, in a small aerosol spray can. None of the internet "touch-up" companies can find the color. I went to my MB dealer, gave my data card to the service rep, he contacted MB but MB no longer shows that 162 Blue/grey ever was, let alone is, available. My best bet will be to have a local painter match the color and let them shoot the hubcaps.
98 911 cab
56 Ford F100
23 Z4M40i
jsaylor
« Reply #10 on: February 25, 2009, 17:51:15 »
For small touch up I've used a product called "Prevail" (Ace Hardware sells it) it is a small baby bottle size bottle with a screw on spray top cartridge,  You can put any paint you wish inside.  It sprays like a spay can.  Any good auto paint supplier should be able to find your paint code.
john.mancini
  • USA, FL, Nokomis
« Reply #11 on: February 25, 2009, 18:07:24 »
Thanks Jim
98 911 cab
56 Ford F100
23 Z4M40i
Rick
  • USA, NV, Gardnerville
« Reply #12 on: March 08, 2009, 16:08:21 »
It is too hard to try to place tape correctly over the star.  I use the plastic tape and lay it over the entire star and beyond it by a bit.  I then use a straight edge and cut the tape down with a razer blade to match the star correctly. This results in a nice clean job.
« Reply #13 on: March 09, 2009, 01:37:20 »
I have done a few of these caps, and the method I used for taping the star is just as Rick mentioned. The lines are clean and smooth. Just tread lightly with the razor knife to not score the metal.
