Author Topic: Removing sticker  (Read 5446 times)
gauchoamigo
Removing sticker
« on: January 30, 2009, 14:29:22 »
I have a sticker I put on the back of the car as a kid that I want to get off. See attached image.
I have 3M Adhesive Remover that I used on the interior of another car and didn't damage it, but I think it is a BAD choice for this application.
Any ideas?
« Last Edit: November 03, 2019, 13:01:56 by Peter van Es »
Re: Removing sticker
« Reply #1 on: January 30, 2009, 15:46:13 »
My guess is the vinyl is now pretty brittle etc but you need to get that off to get to the adhesive.
Once there, I am sure there are all manner of proprietary products but most will be either alcohol or oil based: nail varnish remover (ask wife), meths, white spirit, wd40.... :o
« Reply #2 on: January 30, 2009, 16:52:25 »
Vinyl stickers can be removed by gently applying heat from a blow dryer for hair (borrow your wife's or girlfriends) and aim not too close to burn the paint, but heat up the adhesive and then a plastic putty knife to gently scrap off the warmed portion.  Work in stages.  Can use vaseline jelly or cream to soften the scraper on the paint.
Has helped me in the past with my sisters now 'deflowered' vw cabriolet.  Dont aske me why she put a ton of flower power stickers on her car and let them bake under the hot New Mexico sun.  The car was eventually repainted due to the fading of paint around the stickers.
Walter
1967 220SL-diesel
Silicon Valley Brian
  • USA, CA, Santa Clara
  • American splitting time between USA and NL
« Reply #3 on: February 08, 2009, 21:13:08 »
Once you get the outer vinyl off, you likely will still have the adhesive residue. I like Goo Gone for that. Works fairly fast, and I have yet to see it damage paint. I would not use nail polish remover, which is usually acetone and can dull the paint. Good luck!
Brian Akre
1967 230 SL, U.S. spec, 050 White, Black top, 116 Kaviar interior, #17,030 of 48,912;
1997 SL 500 Sport, U.S. spec, 269 Tourmaline Green, Parchment interior, #145,506 of 204,940;
1991 Nissan Figaro, Emerald Green, #15,717 of 20,073;
2023 Volvo S60 Recharge (hybrid), Black, daily driver
Bob G MN
« Reply #4 on: February 17, 2009, 19:33:10 »
Call 3M adhesives division Tech Service and ask for advice.  The number is 1 800 362 3550
jameshoward
« Reply #5 on: February 18, 2009, 06:34:07 »
Goo Gone is good because it's an organic compound (made or citrus or something). Alternatively just remove the stick using a hair dryer as mentioned below, and then polish away any residue with T-Cut or any other polish that cuts the top layer of lacquer to improve the look of the paint.
JH
James Howard
1966 LHD 230SL
