Become a
Full Member
Emergency Contact List
Body, interior, paint, chrome, and cosmetic items
Glove box fork and spring mechanism
Pages:
All
Topic: Glove box fork and spring mechanism (Read 27939 times)
gzmavian
Re: Glove box fork and spring mechanism
Reply #25 on:
August 01, 2010, 23:44:48 »
Well, this is a follow up on completion of the glovebox spring tube project. It works perfectly ! Alfred, great engineering intuition. A simple solution to a frustration problem. Thanks, Greg
Anfinn
Reply #26 on:
August 06, 2010, 18:23:59 »
Alternative source for the tube:
IKEA floorlamp. I,m sure no-one at home will discover that I chopped 50 mm off the top of the lamp in the den.
tuultyme
Reply #27 on:
August 13, 2010, 17:25:35 »
I found a spring at Ace Hardware that was of the correct size; length and diameter but was stronger (thicker material). This has worked great without the extra sleeve.
tel76
Associate Member
Gold
United Kingdom, Isle of Man, Douglas
Reply #28 on:
September 06, 2010, 20:28:48 »
Hello Alfred,
Where the door lever (the half moon item) goes through the glove box is there a piece of metal to tidy up the hole in the covering material? A photograph of the glove box with the door open and fitted would help with this query.
Eric
Full Member
Platinum
USA, CA, Solana Beach
Reply #29 on:
September 06, 2010, 21:31:17 »
Hi Eric,
yes there is, but NLA. A member of the German group sells excellent reproductions should you need one:
http://www.pagodentreff.de/diskussionsforum/t7274-rosette-handschuhfach.html
1966 230SL automatic 334G light blue (
sold
Full Member
Platinum
Australia, Victoria, Kyneton and Brisbane Queensland
Audit Committee
Reply #30 on:
September 07, 2010, 06:41:32 »
I also bought one from Dave Gallon last year so he may still have some
1972 MB 280CE W114 Auto RHD 906G
tel76
Associate Member
Gold
Reply #31 on:
September 07, 2010, 08:28:16 »
Alfred,
Can you interperate the information on the site you mention,how much do they want and what is the address/ phone #?
On your photograph there appears to be two rubber buffers at the top left and right side (i have two holes only)is there any screws behind the buffers an d do you have the part # of the buffers
Eric
Full Member
Platinum
Reply #32 on:
September 07, 2010, 16:16:11 »
Hi Eric,
sent you a PM with the ordering info.
I do not have the original p/n for the two rubber buffers but I do know that MB lists a replacement p/n. However,
don't buy
them, they will not fit properly! They are too thick and the door shows a gap.
sold
jacovdw
Reply #33 on:
September 10, 2010, 10:19:31 »
Hello Alfred,
Would you be so kind as to send the ordering info to me too via PM please.
I'm also missing that little metal trim ring on my pagoda (compliments of the PO...
Thanks in advance.
Pages:
All
