Author Topic: Restoration update - inspired by this website  (Read 7456 times)
marti
« on: January 19, 2009, 07:23:35 »
    If you ever have wondered if taking the time to post pictures or share advise on this website it helpful, allow me to share with you a success story in way of saying thanks to all of you!      I have always wanted to work on cars.   When I bought my 230sl I finally had my chance.  Unfortunately, my car knowledge was limited to knowing how to put gas in them and check the oil.  Well, thanks to all the thoughtful, insightful and educated individuals who responded to my posts, and the search engine on this site, today I finished fixing my passenger door!  I did it all by myself, I might add -- not bad for a girl!
   My passenger window had collasped inward and I was afraid it would break if I shut the door without the window rolled down.  So I took off the door panel and found the "guide jaws" were sitting in the bottom of the door well.  I ordered the replacement guides from Ray and installed them.  After I finally got them on -- the door glass still was really wobbly.  I decided to go ahead and put the original guide jaws back on.  So I removed the felt guides, cleaned the tracks (again) and put on the guide jaws.  OOPS!  I put them on backwards!  I carefully removed the jaws, glue and cleaned the tracks again.  I put them on the right way and IT WORKED!!!  The window rolls up smooth and perfect flush with the weather stripping.  Speaking of weatherstripping.  Mine was cracked and old so I placed an order with Ray and got new rubber stripping.  I carefully applied the glue to the weather stripping and applied it to the door.  OOPS -- I covered up all the holes with weather stripping so the screws wouldn't go in.  I took off the weatherstripping, cleaned off the glue (again) and reapplied (minus the holes).  It to turned out perfect.  In the mean time, I had to try to screw screws in between the door jam so I bought a tool I thought would work...actually, I bought a lot of tools and tried to set the screw.  After 7 hours, I finally figured out that the "socket wrench" needed to have a "philips head bit" in the end inorder for it to work.  (I thought the end of the socket wrench went around the outside of the screw).  I cleaned out everything, put the plastic on as advised and followed every piece of advice I read.
     Thanks to all of you who have come before and been kind enough to put together the technical manual, answer "newbie" questions and share your valuable iknowledge.
     In case your wondering, the next project is to replace my dark blue soft top--mine is so old it won't even open up.  I can't wait to start my search to see how to do this next challenge.   Wish me luck!!
Marti
63 230sl Euro
Re: Restoration update - inspired by this website
« Reply #1 on: January 19, 2009, 07:56:13 »
Good luck! And thanks for the feedback and success story! Post more... make pictures, share your knowledge!
« Reply #2 on: January 19, 2009, 09:38:57 »
Oh I do wish you'd not posted that
I have wobbly windows and they annoy me and despite being a bloke, am similarly "spannerly challenged" have been wondering if this was a job I could attack myself
It looks like my excuses are running out. Well done you
MichaelB.
« Reply #3 on: January 19, 2009, 18:58:46 »
Marti!
Great post. I would bet that you took great care and had patience that many men do not. I have found that many ladies are excellent techs when they take a shot at the work. Meticulous and careful / two great traits that are admirable in the fairer sex.
Bravo.
« Reply #4 on: January 19, 2009, 20:59:01 »
Are you suggesting that hitting it with a big hammer is not the solution? ;)
« Reply #5 on: January 19, 2009, 22:37:13 »
Only if it is Metric.  S.A.E. and Whitworth hammers are not calibrated correctly.
MichaelB.
« Reply #6 on: January 20, 2009, 00:06:09 »
Ha!  ;D ;D ;D
Witt
« Reply #7 on: January 20, 2009, 20:52:56 »
Bravo !!!!!!!!!...... sounds all to familiar.......that is how I got started about thirtysome years ago and it turned into a full time profession which I just retired from....
You probably are not going to listen to my advise, but here it is anyway: DO NOT TRY TO INSTALL THE SOFT TOP YOURSELF !!!!! You are going to hate yourself for trying.....
I have installed a few myself over the years, mostly on British sportscars, but the Pagoda top is much more complicated ! My new top was installed by an expert, even though I do ALL other work on the car my self !
I am looking forward to your ongoing reports.
CHEERS !
WITT !
« Last Edit: January 20, 2009, 21:08:17 by Witt »
marti
« Reply #8 on: January 22, 2009, 03:37:40 »
Thanks for the advise on the soft top.  I think I may already be in trouble.  I bought the blue soft top already and when I started doing research found out there is something different in the 1963 230's than in later cars -- my car's vin shows it is #244 off the first year production line.  Hopefully, a professional will be able to tell me if the top will work or not.  I think I will be able to find a place here locally -- if nothing else, I can alway chec k in Los Angeles for someone who knows more about what they are doing.  I think I will stick to fixing the weather stripping on the driver's door since it is falling off.   -- easy fix...less money....and still fun to do!  I washed the car this week and checked my "seal".  For once, I had no water in the enterior.
Thanks for responding
marti
1963 230sl Euro
« Reply #9 on: January 22, 2009, 10:09:12 »
marti
does the following thread have any bearing on your soft-top issue?
http://www.sl113.org/forums/index.php?topic=10104.0
