with our official
Pagoda SL Group logo
from our official partner.
Weird Engine Number
Topic: Weird Engine Number (Read 7366 times)
SteveK
Weird Engine Number
January 04, 2009, 16:43:08 »
Hi all, just started working on my car and find I have an engine number I can not identify. It has a E-9.5 on top and then below it has 130 016 08 01. My car is a 230SL and I was told the engine had been changed to a 280SL engine sometime during its life. It's running real well but I would still like to figure this out. Any ideas?
SteveK
Re: Weird Engine Number
January 04, 2009, 18:36:05 »
Looks like I messed up and read the head number instead of the block number. I re-looked and found 130-983-12-008895. Now I understand what I have
Still will have to figure out what transfered over with it when it came?
Klaus
Reply #2 on:
January 05, 2009, 15:10:17 »
The E-9.5 is actually meant to be a Greek Epsilon and says that the compression ratio of the engine is 9.5
graphic66
Reply #3 on:
January 05, 2009, 18:45:03 »
Premium fuel only, if it is 9.5:1. Or as you say it could be a 9.5:1 head and some other block.
SteveK
Reply #4 on:
January 06, 2009, 02:29:13 »
Thanks for the insight. So far all I have put in was premium so I'll stick with it!
Full Member
Platinum
USA, OH, Blacklick
Reply #5 on:
January 07, 2009, 03:05:12 »
Yes yours is a late 280SL engine. Here is a chart showing your cylinder head number
Last Edit: January 07, 2009, 03:06:46 by ja17
SteveK
Reply #6 on:
January 08, 2009, 02:29:12 »
Excellent data, thanks!!!!!!!!!!!!! Next question: would it be safe to assume that when this engine was installed, all of the periferals from the 230 engine would have stayed, or are there components that may have come from the 280sl?
Full Member
Platinum
USA, OH, Blacklick
Reply #7 on:
January 10, 2009, 03:53:37 »
Most parts are the same or closely resemble each other. I can't really answere the question without seein what is in there.
Associate Member
Platinum
Canada, ON, Port Lambton
Reply #8 on:
January 12, 2009, 01:45:15 »
The late 280SL engine is very different from a 23oSL engine. At the least you would want to have the stronger 280SL clutch and pressure plate - the 230SL unit would probably slip. Some of the plumbing around the engine is also different so you have to figure this out in a way that makes it all work.
I did a 250SL that had the late 280 engine in a box of parts. The rebuild went OK but when I started the engine it wanted to over heat. I changed the water pump and thermostat but it made no difference. I've never had this problem before and how I fixed it was to change the thermostat housing cover. The replacement had a place for a thermo switch to be installed. I removed that and filled the system with coolant until it just began to run out the hole. After installing a screw plug the engine started and ran right at 180 and came up to temp at a slow even pace. One thing to watch out for is a sudden and drastic rise in temperature when the car is started from cold. This usually indicates air in the cooling system. It will over heat very quickly while a normal system rises slowly and stops at the rated thermostat temp.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Weird Engine Number
