W113 Pagoda SL Group => General Discussion => Topic started by: Figoulu on April 14, 2025, 12:53:18
Title: big mistake... [updated: no 😇]
Post by: Figoulu on April 14, 2025, 12:53:18
Hello all
I was happy to get my engine overhauled and before putting it back in the car I checked various elements, from which the valve clearance.
Suprisingly almost none was correct, and I checked twice so happy to have made the chekings as the engine was outside
I put everything back inside the car, put oil, check again all the wires and connections and tried to start the engine.
Half a second later the engine was stuck as if the battery was dead.
I understood quickly that some pistons met some valve...
I figured out that as my head has been machined, the thickness of it is different so as the valve clearance. Actually I understand now that the original clearances were correct...
Now what to do ?
I sent an endoscopic camera. Nothing bad so far from what I could see. The engine only turned 1/2 a second.
I want to remove the head and see what to cure.
Probably I will need to cut the timing chain to be able to remove the head, unless I can remove the camshaft gear as well as the belt tensioner to let it go
Once this will be solve what shall I fear as damage ?
I assume only the head as to be checked, what about the block and the rest of it
I'm really stupid... but that's the costly way to learn
Title: Re: big mistake....
Post by: Peter on April 14, 2025, 13:52:45
Engine is build-in  again: then I would set de clearance correct and see how the engine performs.
Alternative is, what also will happen when the engine does not perform nicely, is again a complete overhaul, as the crankshaft could be (minimally) bended, the crankshaft bearing can be “oval”, valves bended,  etc…..
I know, a horror scenario. Sorry for this.
Post by: Cees Klumper on April 14, 2025, 14:21:20
I would not expect the skim of the head would be so much that setting the valve clearances to original specifications would cause the valves to hit the pistons. The machine shop would have had to remove a lot of material.
 What I would do:
- try turning the engine by hand after removing all spark plugs
- double and triple check the engine timing: valves vs pistons vs ignition
- if engine spins freely by hand then use the starter to spin the engine briefly
- try starting it again, if the engine spins freely
Could it be that there is 'something' obstructing the free movement of the engine, such as a wrench, the timing chain, a loose bolt somewhere?
Post by: Figoulu on April 14, 2025, 14:45:48
 What I would do:
Impossible to turn the engine even with the spark plug removed... in one way and in the other way
I have no idea if something else could have blocked the engine... yes could be a nut, but nothing like a tool, I don't believe that
I guess the only way to see more is to remove the head, but there might be a way to loosen the head and remove the timing chain other than to cut it. With removing the camshaft gear ??
I forgot to mention that the endoscopic camera shows the very slight print of a valve... But I agree with you, how could the machine had potentially removed so much "meat"... so that the valve met the pistons
Before doing all this I had checked the timing and everything was well synchronised...
Post by: yves on April 14, 2025, 17:18:55
What about à timing chain opened ? And blocked ?
Post by: MikeSimon on April 14, 2025, 18:13:26
I would guess that the cam chain was not installed properly and a valve protrudes into the cylinder when the piston is at TDC and caused the interference. The head comes off from the engine with the engine installed. It is a hassle, but not a problem.
Post by: Figoulu on April 14, 2025, 18:53:47
How about the chain ? How would you remove it ? Shall I remove the camshaft gear ?
As far as I remember the timing was ok. I checked it when doing my valve clearance
Post by: waltklatt on April 14, 2025, 23:42:47
Bummer to hear that.  I would take cam cover off and look at the valves to make sure all of them are still in place(not dropped).
Then do like others said, remove plugs and try to turn by hand.
If nothing, mark location of camshaft to chain sprocket wheel and make sure you don't loose timing marks.
If the camshaft is in wrong position(180 degrees) off from crank, then the timing is all off.
Reset by turning the crank and camshaft independently till you line them up properly.
You said you spun the motor briefly, then you should be ok with unbent valves and uncompromised pistons.
I don't know how much you spun the motor before locking up.
Go ahead and cut the chain and remove head.  New chain and head gasket is in order.
Have head and valves fixed(pressure test).
Bought a 1970 280SE with the timing turned 180 degrees off and the valves were trashed.
Got a new motor and installed it, with no problems.
That was many years ago.
Walter
1967 220SL diesel
1969 280SE
2003 Beetle TDI
2005 Honda Element
Post by: DaveB on April 15, 2025, 02:08:32
I wouldn’t think it’s necessarily pistons hitting valves Figoulu. I believe the engine would likely still turn one way or the other in that case. Could the starter have got jammed somehow? Maybe take it off and have  look. If you didn’t hear anything disastrous hopefully the engine internals are ok.
Post by: Benz Dr. on April 15, 2025, 05:28:03
No need to cut the chain. Remove the chain tensioner which should take some of the tightness out of the chain.
You have a valve hitting a piston which indicates incorrect valve timing. Even one tooth advanced will make valves hit pistons. Two teeth advanced and the engine will lock up solid.
No need to remove the head if you can retime your camshaft.
Post by: Figoulu on April 15, 2025, 05:40:51
Thanks for your advice.
I will do it asap
For the Time being I need to stay away from that car…
Post by: stickandrudderman on April 15, 2025, 07:21:33
Check again your valve clearances. If they have increased since you set them then that is an indicator of bent valves due to incorrect camshaft timing.
If they are bent then you'll need to remove the cylinder head and renew the bent valves.
Post by: Figoulu on April 15, 2025, 08:47:09
Thanks a lot for the advise !
My pro went back to me and ask me to send it back to him
Post by: Peter on April 15, 2025, 12:53:15
We are of course very interested in what the diagnosis is, please keep us informed.
Post by: Figoulu on April 16, 2025, 04:24:38
Thanks to all for your messages including pm
At the end of the day the engine will be sent back to the pro.
When removing it from the car I will try to investigate something by just removing the rocker arm cover just to see if something obvious appears
I will post the end of the story when I know more.
For those who know the answer, do we expect the engine block/ piston / rods to be damaged or only head and valves?
Post by: DaveB on April 16, 2025, 08:51:46
That seems the best thing to do, especially if you had not altered anything after receiving the engine from them. Good luck.
Post by: RAY on April 16, 2025, 17:25:12
Regarding the machine shop removing a lot of material may not necessarily the case. It may just be that the head had already been skimmed once or twice before ?
Post by: ja17 on April 17, 2025, 04:44:35
Remove all spark plugs. Remove all the rocker arms that can be removed with the head still on the car. Next increase the clearances of the valves on the remaining rocker arms on the car until they can be removed or the engine can be turned again. Proceed until all rocker arms are removed. Next turn the engine and check the valve timing marks. Correct if needed. Next, install each rocker arm one at a time and set the valve clearance to specs.
Continue until finished, one at a time until finished or until problem occurs.
Post by: Figoulu on April 17, 2025, 07:50:54
Thanks again
In the best and the worst case, what kind of damage could I expect ?
Do you think the piston / crankshaft  could have been damaged or only head / valve ?
Once again the engine just try to start for one second
Secondly, how can I determine the new specs for the valve clearance ??
Post by: twistedtree on April 17, 2025, 17:00:03
This ^^.  It seems most likely that whoever reassembled the engine got the cam/valve timing wrong.
Post by: Cees Klumper on April 17, 2025, 20:59:19
While that makes sense, anyone rebuilding an engine, or even just replacing a timing chain (or timing belt), would verify timing by turning the engine over at least two complete revolutions to confirm no interference. Certainly any professional rebuilder/mechanic should!
Post by: Figoulu on April 18, 2025, 09:31:02
It's not clear for me if the issue comes from a lack of control and the bad timing tuning because as far as I remember I have checked previously the alignement of the various indexes to be at TDC. And when I made the valve clearance tour, it's almost sure that previously the engine was freely truning.
this is why I guess the corrections I made to tune as the original spec made the mess, or alternatively as it has been also suggested, something like a chain link or whatever loosen screw, has blocked the rotation. this week end I will investigate because I don't hide that removing the engine doesn't please me so much... because I will need to fight again to put it back in the car... So much fun to come...
Post by: Cees Klumper on April 18, 2025, 12:56:09
It is true that in order to check and set the valve clearances, you would have had to rotate the engine at least to some degree (pun intended). I am thinking a bolt or other object is obstructing the rotation. Wish I was there to help diagnose, good luck with the investigation ... Do try out the various suggestions by Joe A and others.
Post by: ja17 on April 18, 2025, 14:25:50
Since the valves are directly perpendicular to the flat top pistons on these engines, you most likely do not have major bottom end damage. The valves do not usually get bent or damaged when they are perpendicular to the pistons. In severe circumstances the valves are jammed upward breaking the camshaft or the cam support. Visual check the cam supports and camshaft closely. Next follow the steps in my previous post. On other engines where the valves enter the combustion chamber at an angle, (not perpendicular to the pistons), a collision between the valves and pistons almost always results in bent valves!
Post by: ja17 on April 18, 2025, 14:42:22
There is always the chance that you had something that was loose and fell into the timing chain and jammed the engine. Examine deep into the chain gallery where the timing chain meets the crankshaft sprocket. In some other case a loose part in the intake manifold can be sucked into the combustion chamber, during start-up, locking up the engine.
Post by: Figoulu on April 18, 2025, 16:39:41
You couldn’t be more accurate…
Here is a quick update…
I could remove all the rocker arms quiet easily and without turning the engine… anyway it still cannot be turned and is totally stuck back and forth…
At least (little satisfaction) it’s not my fault…
I’m gonna try to investigate but it’s quiet difficult to do without removing the head which I don’t want to do just to avoid to break the warranty…
I sent one more time the endoscope but nothing obvious. The top of the pistons are clean… just a very gentle stamp of a valve on top of some pistons
Post by: Figoulu on April 18, 2025, 17:05:45
As the camshaft is positioned, we are a TDC on the cyl 4….
As the firing order is 153 624 next cylinder to be fired is number 1.
It’s hard to say like this, but the alignment of the distributor, the mark on the crankshaft pulley and the one on the camshaft appears to be somehow consistent to be at TDC of cyl 1 if we could turn the engine more… see the red lines on the pictures that emphasizes the indexes…
It appears to me that there must be something else blocking the engine.
I think I could not do more to get the answer, in order to avoid to break the warranty of the engine but I bet it’s not because of my valve clearance tuning that the engine is stuck.
Post by: Figoulu on April 18, 2025, 18:48:48
Now I that I removed the rocker arm cover, I could see clearly the chain link… it’s definitely there and properly locked.
Title: Re: big mistake... [updated: no 😇]
Post by: BobH on April 18, 2025, 20:01:11
Just a complete guess, but could the starter motor get jammed on the flywheel?
Post by: Figoulu on April 18, 2025, 20:11:44
Very good idea indeed
I was thinking about to test it… remove it first and check if it could be the culprit… Same applies with the flywheel where something could be stuck around this area…
I did a complete overhaul of the starter myself here https://youtu.be/8ghKjPeb10s?si=Xv8mUc9FmKh2V1OI
… but who knows ?
Post by: yves on April 18, 2025, 20:46:36
Hi François, your motor adventure is like a netflix série🙈 a cliff hanger at each end of post …!
But i think that you are close to the solution.
WE are with you on that issue.
Post by: Cees Klumper on April 19, 2025, 00:48:55
Yes I would just remove the starter, not a big job, and see if that frees up the engine.
Post by: ja17 on April 19, 2025, 04:13:25
Good thought on the starter Bob H !
Post by: Figoulu on April 19, 2025, 07:08:34
Thanks Yves 😁
Frankly spoken I’m in a way « happy » that apparently I’m not guilty with having done the valve clearance tuning even if it’s a lesson learned, for next time...
By the way in general cases, we normally compensate the head machining, by a head gasket with a thickness corresponding to the material removed, but why on our cars do we have only one ref of head gasket whatever the final thickness of the head is ?
Anybody has the answer ?
Post by: Figoulu on April 19, 2025, 07:11:52
That’ll be the next step guys 😁😁 after I get my Easter lunch with my mom… she lives 200kms from my house so I guess you’ll get some fresh news tomorrow, Sunday 😉😉
Post by: Figoulu on April 20, 2025, 12:29:31
Yep…
The starter is totally stuck guys
Now I need to try to remove it. As of now I couldn’t see how to do and if it has damaged the flywheel 😁
Post by: Figoulu on April 20, 2025, 12:41:46
Conclusion: starter 1 / flywheel 0
The engine turns by hand smoothly…
Just need to put back the rocker arms and get to know the correct values even if it doesn’t seem to be problematic in my case…
Post by: Figoulu on April 20, 2025, 12:47:10
No idea yet how to fix it but it’s sold apart… anybody to tell me ?
Post by: wwheeler on April 20, 2025, 13:17:49
Replacing the ring gear is a common repair. The old one gets machined or pressed off. New ring gear is heated to expand and then pressed on. Any shop that deals with clutches should be able to do it.
Post by: Cees Klumper on April 20, 2025, 13:30:38
So ...good news on Easter ...
Post by: Philippe VIARD on April 20, 2025, 15:07:10
Je l'ai fait sur une Triumph TR6. Pour remettre la couronne et selon le livre d'atelier du véhicule, il faut la mettre dans un récipient contenant de l'huile moteur et chauffer l'ensemble . La remise en place s'est bien passée. Je n'ai pas le livre sous la main mais je pourrai si cela vous intéresse vous donner les durée de chauffage et la température à obtenir.
Post by: Figoulu on April 20, 2025, 17:53:27
Good to know. I’m gonna see with my pro how to adress this issue between he and I.
What is your analysis about the reason it went like this ?
Post by: Figoulu on April 20, 2025, 17:56:44
Yes indeed… I agree.
I’d like to take this opportunity to warmly thank all of you with leads and supportive comments. It’s been a pleasure to post and receive interesting answers. Special thanks for those who pm me and of course for the ones who got the right clue @Daveb and @BobH 👍👍👍👍
Post by: Figoulu on April 20, 2025, 17:59:12
Thank you. The best is for me to see directly with the pro who might send me a new flywheel while I would send him back the damaged part. Once again I would like to understand how all this could happen ?
Post by: Figoulu on April 20, 2025, 18:06:18
As of tonight I removed the intake and exhaust
Removed different connections
I have left for tomorrow:
- gearbox support
- rear axle connexions
- power steering pump
I’ll remove the engine from the car and separate the gearbox.
See you tomorrow for the next steps!
Post by: yves on April 20, 2025, 20:14:23
What a job already made👍, keep on!
And stay safe …🏋️
Post by: Benz Dr. on April 20, 2025, 20:25:36
Ring gear is easily removed with a dull chisel. Keep hitting on the ring until it starts to slide off of the flywheel. Place the new ring gear on the flywheel after heating with a torch and it should pretty much drop into place. Once it cools it will be more than tight enough.
Post by: DaveB on April 20, 2025, 23:09:17
That’s great news, no engine damage!
But may I direct you to reply #8 in this thread? 😉
Maybe ask your mechanic if the starter may have caused the problem. Otherwise it might happen again..
Post by: DaveB on April 21, 2025, 06:12:40
Is it because the extra clearance can be taken up at the ball studs?
Post by: Figoulu on April 21, 2025, 06:31:57
Yes sorry this one fell off the radar. Message #42 correctes 😁 Thanks for having given the right lead after only some messages 👍👍
My idea was to try to use the starter again once the engine is outside. I don’t see the problem to try again if I can properly stabilize the engine. I want to know wether the starter or the flywheel ring is the problem.
Post by: Figoulu on April 21, 2025, 06:33:17
For this job do I need to remove the flywheel from the crankshaft? I guess yes
Post by: Figoulu on April 21, 2025, 06:40:19
Could be but as any other system you can compensate as well
My question is now how much would be the good clearance… my pro do not answered yet… if I could measure with a gauge the journey of the valve and compare it with original spec it could be the solution. But as it is engineered I think I can’t
Post by: BobH on April 21, 2025, 07:08:00
If you think about it, the flywheel is sitting there, minding its own business, and it's suddenly assaulted by the starter gear, flying out of nowhere, it's bound to get a bit bruised and beaten over the years.  Added to that, if it's true that the engine always comes to rest in one of a few positions (i don't know if that's true, but sounds reasonable), then the same few teeth on the gear ring will be subject to the wear and tear.  Added to that there is no lubrication, like with most meshed gears.  Perhaps your starter wasn't making good contact with the gear ring before you refurbished it, good video by the way, and perhaps that caused more damage to some of the teeth.
I think the gear ring is made to be sacrificial, a bit like the iron rim on a cartwheel, hence why it can be replaced, not bad if its lasted over 50 years!
Just make sure the starter makes good contact with the new gear ring when you assemble it again
So glad it wasn't too much of a problem for you!
Post by: BobH on April 21, 2025, 07:10:47
https://www.bing.com/images/search?view=detailV2&ccid=iVpqPNmc&id=1638BD6E5052AC06B6B32E939AD307CC12A4BEA1&thid=OIP.iVpqPNmcqpf9CPdyjjqS2gHaEK&mediaurl=https://i.ytimg.com/vi/ruNBZFYEbek/maxresdefault.jpg&q=how+to+replace+ring+gear+on+flywheel&ck=247B547937658A194FB3E9BF961E22A7&idpp=rc&idpview=singleimage&form=rc2idp&mode=overlay
Post by: Figoulu on April 21, 2025, 08:53:24
Easy 😅😅😅
Thanks 👍
Post by: Figoulu on April 21, 2025, 09:56:46
Countdown to lift off…😁
Post by: Pawel66 on April 21, 2025, 11:39:44
I like the Trabant thing.
Post by: Figoulu on April 21, 2025, 12:01:26
A souvenir from my hungarian period when I lived in Budapest. Such a car would cost 150€ complete… they were useless because they couldn’t pass the pollution test and couldn’t be driven anymore…
Post by: Pawel66 on April 21, 2025, 12:16:11
Tell me about it... my father owned two of them.
Ok, not to ruin your thread, sorry.
Post by: Figoulu on April 21, 2025, 13:36:38
Nothing too much
When I lived there we could ask any kind of decoration… as a symbol of an era I decided to ask to get a front to remember those days in my garage…
By the way… perfect landing
Post by: Figoulu on April 21, 2025, 17:25:23
Rocker arms back. Clearance given by my pro: intake 0.15 mm exhaust 0.20mm which is now set up even if it’s not totally logical to put + 0.02 for the exhaust and +0.07 for the intake…
Saw also the gear… definitely it has lived because there is at least one more damage done previously… a cheap savings my pro did…
Post by: Figoulu on April 23, 2025, 04:57:05
Before I remove the flywheel I wanted to test my starter and see if I can activate the rotation of the engine and let the oil pressure rise up
https://youtu.be/SDMJsD6YD3o?si=XqcFypwCF1eBC13v
As you can tell the pressure is ok at least drops of fresh oil falls on the rocket arms I guess the oil circuit is about to be fully under pressure
But you can also hear a bad repeating noise…
To make sure it was about my damaged flywheel and the interaction with the starter I made a slow motion video and marked the 2 damaged gear with red line on a tape located just in front of them. I got immediately the answer…
https://youtu.be/zegj6UV4rvQ?si=H8r7YPl343zk3R2J
Post by: Bshaunessy on April 23, 2025, 14:23:52
FIGOULU:
  Loving this serpentine journey you are on , and your documentation and pics….both entertaining and informative.  ( I thin you are in the final chapter now?)
Post by: Figoulu on April 24, 2025, 07:49:55
FIGOULU:
I try to make it live and tell a story from A to Z to make sense and interest... So frustrated to see posts without the final solution
So... Yes, the parcel has been sent yesterday to my pro who is in Germany.
With all those events I wanted to make it to the safe side and bought a new starter just in case mine was not 100% reliable and could possibly be part of the trouble.
Apart from that I have ordered couples of very last missing parts / or to be replaced to be able to get back very soon with a running engine.
I dont but the pressure on myself and gave me a 3 weeks time to get back the flywheel from my pro with a new gear and the last missing parts.
I'll give you the next episode for sure untill this engine runs and the car drives !
Thanks for your interest
Post by: Benz Dr. on April 24, 2025, 14:25:20
.003 intake and .007 for exhaust.
Post by: Figoulu on April 24, 2025, 16:24:28
Yes those are the original value for the valve clearances but provided that the head has been machined I guess we cannot stand with the original values and possibly run the risk that piston and valve get married against theit own will  :o
Post by: Benz Dr. on April 24, 2025, 17:13:36
Not likely but this how you check:
turn your crankshaft over to 5 degrees ATDC on number one cylinder. Pry the intake rocker down until you feel it hit the top of the piston.  If you have a dial indicator you can use that to check liner movement or you can see if a .040 feeler gauge will will slide in between the rocker arm and the cam lobe. If it will easily slide into place you should be good to go. If the gauge is too tight try a thinner combination until you find a size that fits. Less than .035 and you may run into trouble.
Only the intake valve can hit the piston during normal operation. Intake valves are supposed to be set to .050 mm recession which is the amount the valve face sits below the parting surface of the cylinder head. If you have  your valves sitting at parting surface level this is the real problem.
.002 for your exhaust is far too tight and you can risk burning out the valve.
Post by: ja17 on April 25, 2025, 04:46:39
Yes, go with the original specs as Dan suggests. The factory allows for the machining of engine parts within specs and it should not effect the valve adjustment.
Post by: Figoulu on April 25, 2025, 07:54:19
Thanks all for those important info
I will check that as the engine is still outside and for some days / weeks again 👍👍👍
Post by: Figoulu on June 30, 2025, 07:56:35
Some updates...
Here in the south of France, the temperature (104°F and more...) is not favourable to make hudge progresses, unless you could work early in the morning or late at night... Anyway...
I finally received a new balanced flywheel, with nice and clean starter gears, so I could put everything back together...
Now what puzzles me, is the movement i can do with the clutch release fork... Does the magnitude is not too much ? here is the short video:
https://youtu.be/DKgxikqmE4E
Before everything is back in the car I just wanna make sure...  ::)
Post by: Figoulu on June 30, 2025, 19:20:30
Nobody to answer my question about the enclosed video ?
Post by: Charles 230SL on June 30, 2025, 20:07:29
Hello Figoulu, the travel on the clutch fork looks fine to me. Remember, the slave cylinder rod pushes the clutch fork toward the rear of the car, subsequently releasing the clutch disc.
The movement you’re seeing is the throwout bearing sliding on the sleeve before it engages the pressure plate.
The tension spring on the clutch fork will limit that travel.
Post by: Figoulu on July 01, 2025, 04:18:25
Thanks for your answer, I was expecting that explanation
Another question is how can we make sure that the 2 little fingers of the bearing stays aligned and in perfect contact with the same on clutch fork ?
See the attached picture which is not genuine to w113 but tries to explained what I’m concerned about
Post by: yves on July 01, 2025, 10:14:37
The clutch level travel seems also fine to me....
Post by: Charles 230SL on July 02, 2025, 00:56:22
..how can we make sure that the 2 little fingers of the bearing stays aligned and in perfect contact with the same on clutch fork?..
The throwout bearing slides back and forth on the sleeve and the sleeve keeps the bearing centered on the pressure plate. On a 230SL the clutch fork "fingers" have spring retainers holding the bearing in place (see pics).
Post by: Figoulu on July 02, 2025, 07:31:16
Thanks for your explanations and pics... I do NOT have those retainers...
Questions solved and... I need to get those retainers and put them to link the fork and the bearing...  ::)
Post by: Pawel66 on July 02, 2025, 10:43:51
They should be available if I read it right...
Post by: Figoulu on July 02, 2025, 14:26:13
Interesting...
I had only in mind the loop shaped ones, not the clips.
Do we need both of them because I can't clearly see how the clips goes into the assembly
Post by: Raymond on July 03, 2025, 01:07:58
Here's a long shot for Joe or the Doctor; Is there a bolt on the left side of the engine that threads all the way into the crankcase?  If so, a bolt that's too long might be interfering.
Post by: Figoulu on July 04, 2025, 09:02:31
Hi Pawel
I looked for those parts but niemoller or sls can't provide the little circle shaped part
Any lead from your side ?
Post by: Duncan200 on July 04, 2025, 09:41:06
The circle part you are looking for is the snap ring that fits in the ball socket that the clutch fork pivots on.
I suspect it’s full of grease and you can’t see the snap ring.
Doug.
Post by: Figoulu on July 04, 2025, 09:54:19
Doug.
Good remark I'll take a look at that before ordering too fast something already inside the fork...  ::)
Post by: Pawel66 on July 04, 2025, 14:44:24
Both are there at Mercedes. Yellow dots mean 72 hrs availability, I guess your place will be no different than mine. Numbers 63 and 62, you have part numbers there. One of the has changed - you have the history. Prices are in PLN, divide by 4,4 and you have them in EURO. The higher amount is with VAT.
Post by: Figoulu on July 04, 2025, 20:48:58
Thanks 👍
Post by: Figoulu on July 07, 2025, 14:20:05
Everything is fine... My pro has pretended that those parts weren't included when i sent him the whole stuff, but... he agreed to send me the 2 parts (clip + hook X 2) free of charge... nice move !  :D
See my mail box soon and keep you updated !
Post by: Benz Dr. on July 07, 2025, 15:19:39
Retainer spring is not installed correctly. Should slide into a hole in the mounting sleeve.
Post by: Figoulu on July 07, 2025, 15:29:16
Any pics / drawing to help ?
Post by: Benz Dr. on July 07, 2025, 16:09:04
Look at the picture of the sleeve with the retainer clip. The straight end of the clip goes into a hole just behind where it is shown in the picture. You will need to unhook the 90 degree end and then find the hole where you start the clip. Clip should be installed straight end first followed by the 90 degree bend or you will probably have a very difficult time getting it to install.
Post by: Figoulu on July 07, 2025, 16:43:29
I'm preparing then for joyfull moments  ;D
Post by: clunker on July 07, 2025, 20:40:49
As Dan says, those clips need to be in the fork and the bearing - there are small holes on each, on each side to receive the clip.
Do the least accessible side clip first, put the bent end of clip in back of fork then rotate bearing to get the straight end in the bearing hole. Then on the other side, rotate bearing into position, put the straight end in first into the bearing hole, then push the bent end back behind the fork and into the hole there.
Post by: Figoulu on July 08, 2025, 06:38:57
Very helpful, thanks ! ;)
Post by: Figoulu on July 20, 2025, 07:36:11
My parcel has arrived… just have to get back to my engine and finish the job…
Post by: Figoulu on July 20, 2025, 18:26:19
Done 😁
Post by: Figoulu on July 20, 2025, 18:28:39
And done also… 😁
Post by: Figoulu on July 20, 2025, 18:29:47
I have my birthday on July 25th who knows if it could be an happy pagoda birthday ?😅
Post by: yves on July 20, 2025, 18:30:51
Well done👍🔜🏎️
Post by: su8pack1 on July 20, 2025, 21:46:04
Job well done.
Post by: Benz Dr. on July 20, 2025, 22:21:54
Done 😁
If you installed the spring according to your picture it's still not mounted correctly.  :(
Post by: Figoulu on July 21, 2025, 00:22:38
There was no hole in the bearing…
Post by: clunker on July 21, 2025, 01:48:54
Was it a new thrust/throwout bearing? if not it really is the time to change it with it all out. A new bearing will have the correct hole, as Dan says.
Post by: Benz Dr. on July 21, 2025, 05:03:57
It should have a hole for the spring. You may have it turned around so that the hole is on the back side.
Post by: Figoulu on July 21, 2025, 07:29:09
Was it a new thrust/throwout bearing? if not it really is the time to change it which it all out. A new bearing will have the correct hole, as Dan says.
It’s a new one…
Post by: Figoulu on July 21, 2025, 07:36:24
My bearing is new, oem from Benz and identical to the old one. I will double check to see if the old one has holes that I missed but I doubt. If no holes, I will leave it like this…
When I fixed everything I tilted the whole assembly several times and grease all the moving parts… everything seemed to be ok and move smoothly… if apparently those retainers were missing when refurbishing the gear box, having it now is already a good move. Considering the pictures sent by Charles230sl it seems working properly, please Charles correct me if I’m wrong…
I can’t hide that I was happy to put the engine back in the bay yesterday for the 3rd time, (which is fun but a bit repetitive 😁). I fully agree that if something is wrong it has to be addressed, but I have the feeling that it could fly as is…
Post by: Sead on July 21, 2025, 08:05:53
Done 😁
As stated by Dan this is clearly wrong. The spring will fall of sooner or later and rear part will start spinning - loose contact with throw out fork.
See attached pictures for correct assembly
Post by: Figoulu on July 21, 2025, 09:03:27
Here is my old bearing… 🙈
I know what to do now 🙈🙈🙈
Post by: Figoulu on July 21, 2025, 10:15:31
Everything is out of the car, gearbox as well and this is my bearing 🙈
I will now drill 2 holes in it 😁
Fun continues 😁
Post by: Figoulu on July 21, 2025, 10:50:52
Finished… and much better
Thanks Dr Benz for your accuracy 😁
Post by: Figoulu on July 21, 2025, 17:24:48
Once again back in the car and I hope this time for good 😁
Post by: Figoulu on July 27, 2025, 18:47:15
And finally… https://www.instagram.com/reel/DMk6t3AIHtQ/?igsh=MWp6YjdzdTlzZ3R1cw==
Post by: AndrewB on July 28, 2025, 16:49:52
sounds good ! Well done
Post by: yves on July 29, 2025, 06:57:51
Well done François, quelle satisfaction d'entendre ce doux ronronnement......!
Post by: Figoulu on July 29, 2025, 08:35:02
Thanks !
Now it's time to put back the radiator and proceed to the tuning...
I have to flush the clutch and check about throttle linkage, ignition timing, and CO ratios
I will fix a lambda sensor in the exaust to measure properly the Air-Fuel-Ratio and ajust the FIP in accordance...
Still 1000kms to do, and then back to oil change, head tightening and that will be it... I hope  ::)
Post by: Figoulu on August 13, 2025, 07:19:06
Changed the rotten sway bar bushings and had some issues to make it without significant amount of force…
I then figured out that it couldn’t work like this because the sway bar was hitting the chassis… see the pic…
Post by: Figoulu on August 13, 2025, 07:22:12
Believe me or not, the sway bar has been set upside down… when I understood it couldn’t be like that I corrected the assembly and it went like a charm…
Post by: Sead on August 13, 2025, 08:06:16
take care to tighten the 4 pcs rubber buffer on swing bar correctly.
two hex head nuts are tightened down until you measure 23 +/-1mm from upper nut to the top end of 200mm long main screw.
Post by: Figoulu on August 13, 2025, 08:16:29
Thanks a lot. I was about to fine tune this part with the references I took in place before replacing them see pic...
Post by: Cees Klumper on August 13, 2025, 10:01:17
You're off 16/100 of a mm  ;D
Post by: Figoulu on August 13, 2025, 10:58:23
Yep that’s my big concern 😁😁
Post by: Duncan200 on August 13, 2025, 11:11:22
Hmmm, that’s not even close to the correct value in the metric system 😂
Post by: Figoulu on August 23, 2025, 07:23:37
Still into my fine tuning I was surprised to see my crankshaft seal positionned that way… I mean not flush against the block. Is it normal ??
