Author Topic: Looking for socket pins w113  (Read 4655 times)
The_Molka
« on: June 26, 2023, 19:32:06 »
hello,
as in subject, i'm looking for new socket pins for w113/w111 in fair price :)
regards T_M
dirkbalter
  • USA, CA, Corona
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Re: Looking for socket pins w113
« Reply #2 on: June 27, 2023, 03:08:50 »
What is this thing?
BobH
« Reply #3 on: June 27, 2023, 07:09:23 »
If you click on the red items in the box on the SLS link all will become clear!
https://www.sls-hh-shop.de/main/en/mercedes-190sl-w121-/54-b-wire-set/contact-bushing-4mm-brass-silver-plated-p-5663
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #4 on: June 27, 2023, 07:11:12 »
I think they are the tiny female electrical plug 'sockets' that are used in the wiring harness, that wires are soldered into.
yves
  • France, Poitou-Charentes
  • Happy owner of a 69/ 280 sl , 63 Etype ,55 XK 140
« Reply #5 on: June 27, 2023, 09:37:44 »
Some detail if needed...!
Happy owner of a 69 blue 280SL ,  63 FHC  osb E-type , 55 FHC XK 140 to be restored...
« Reply #6 on: June 27, 2023, 16:30:09 »
Oh, they go inside connectors.  Cool.
Desertpagoda
  • USA, AZ, Tucson
« Reply #7 on: October 20, 2023, 22:34:31 »
Mercedes used to call them "bushings"
kb
MikeSimon
  • USA, OH, North Royalton
« Reply #8 on: October 21, 2023, 17:43:25 »
No. Mercedes did not call them "bushings". Bushing is not a German word. They may have called them "Hülse", maybe.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #9 on: October 21, 2023, 19:57:33 »
There are many standards for these pins that go inside plug fittings. You just have to figure out which one!
In a former life with computers, I used to use a lot of these that were made by Amphenol. They were crimp fittings, and there  were small, inexpensive tools to both crimp them, and to place them inside the plastic connectors, and remove them from the connectors when needed. I would imagine the same exist for whatever standard these connectors are.
« Reply #10 on: October 21, 2023, 20:33:37 »
hello,
regards T_M
If I understand correctly what you are looking for is all here: https://www.sl113.org/wiki/Electrical/Connectors
The simplest way of getting them is at Mercedes. You will also get the right size by following the part numbers.
Fair price - they do not cost a fortune (ca $1-2), so unless you are after a couple of thousands, perhaps it is acceptable. You do not risk getting the wrong part. And you do not pay shipping, which would probably exceed value of connectors if you want 5-10 of them.
They are called contact pin or contact sockets.
Just modified this post by adding the below:
A good way of looking for "fair price" is to cross-reference the manufacturer part number with other manufacturers part numbers in a good internet store. If you take the pin bushing A 001 545 38 26 and cross reference it, you will get, for example, this:
https://www.iparts.pl/czesc/wtyk-herthbuss-50253950-herthbuss-elparts-50253950,0-72-50253950-3928266.html
Then if you check further in the tag "OEM Numbers" you will get part numbers for other producers.
They are not, however, available. This internet store, iparts, is a part of a large network and usually have better availabilities than other retailers.
The price is a little over $1. Then you add shipment - that is why I buy some of these things from Mercedes.
« Last Edit: October 22, 2023, 09:59:43 by Pawel66 »
Desertpagoda
  • USA, AZ, Tucson
kb
cfm65@me.com
  • Cape Town, South Africa
« Reply #12 on: November 25, 2023, 15:44:03 »
Hi Molka,
How many do you need?
Male or female?
Chris
Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
