Author Topic: Nardi steering wheels  (Read 28701 times)
Re: Nardi steering wheels
« Reply #25 on: November 20, 2006, 17:43:23 »
I consider the classic Nardi wheels to be the true classic steering wheels for our vintage years 1963 to 1971. The Nardi I speaak of you might of seen onsome 300SL gullwings or roadsters. the horn button is large with the Mercedes-Benz star prowdly showing and the wheel is a bit the sizr of the of our standard steering wheels. The rim is slimmmer and the wood different. I guess this is a true glove wheel.
But that is just my take. I had a leather Nardi on my 280SL when I got it but took it off and sold it to replace it with an ivory wheel and center pad. O like the look of the orginal wheels and the feel.
1968 280SL
Khurram Darugar
« Reply #26 on: November 21, 2006, 08:09:35 »
Dana,
     Thanks it was so dead simple i did'nt (Duhh) consider it.
    The bigger nardi wheel while super rare, 300sl etc etc ...... to me looks like a boat wheel.  I like a midsize nardi simply for classic looks.  Ergonomics wise not ideal as the rim is right in the middle of the speedo, but besides that nardi looks sportier than the standard wheel.
I guess at the end to the day it depends what look you prefer.
Kay
Kay
Euro 280sl LHD Auto.
« Reply #27 on: August 21, 2010, 17:42:06 »
You just need to pop the ring off.   Mine actually has rubber where the bolt heads are covered making it difficult to remove like yours.
I got the ring off and the nut on the splined shaft (3rd photo) and now want to get the bowl together with the wheel off but it is stuck firmly. Do I need a puller or are there any other tricks?
« Reply #28 on: August 21, 2010, 21:46:20 »
Hi Alfred,
The shaft is tappered and the hub has been pressed down by the big nut and is now stuck.  Try some penetrating oil and then wiggle the wheel back and forth while pulling it off.  With your third hand gently tap a block of oak on top of the shaft with a hammer .
« Last Edit: August 21, 2010, 21:48:55 by jeffc280sl »
Norm
  • USA, TX, Wimberley
« Reply #29 on: August 21, 2010, 22:51:49 »
As a slight variation to Jeff's post above, I had a Nardi "stuck" on the shaft and while I wiggled and pulled, another leaned in and tapped the shaft with a hammer and punch.  It was pretty violent for a minute but it came off with no damage to anything.
Norm
Norm
1966 230SL 162H Blue-Grey
1994 Acura NSX Formula Red
2024 Acura RDX A-Spec, White Pearl
2016 Mercedes S63 AMG Coupe Obsidian Black
2011 Harley Davidson Super Glide Light / Dark Root Beer
« Reply #30 on: August 22, 2010, 02:23:04 »
Thanks Norm and Jeff.
I guess violence sometimes pays off - the punch and hammer method worked!  :o
