W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: BaronYoungman on November 28, 2020, 05:18:47
I have watched this gentleman for years test different things , he is paid by no supplier and uses a very scientific approach. He put this one up on ethanol and how it affects aluminum and other things inside a carburetor which is also applicable to our fuel injection systems. He is testing if stabilizer helps. I found this to be very Illuminating on the detrimental effects ethanol has on all of our parts. If you don't see anything else go to 4 minutes and 19 seconds into the video and see what 9 months does to a piece of aluminum in gasoline with 10% ethanol and some water contamination...scary
https://m.youtube.com/watch?v=UvS_D4_lF5U&t=33s
in contrast to this contribution, the Mobile Future Institute (IMZU) carried out a long-term test with 20 vintage cars of different ages and almost 1 million kilometers covered for E10 compatibility with the result that in no case did this cause any damage.
The vintage car magazine Oldtimer Markt reported: "Three years after the introduction of the" biofuel type "Super E10, it is time to take stock. Has the state-prescribed alcohol consumption harmed our old sweetheart? The answer is soberingly simple: No!".
The discussion about petrol, engine oil etc. and their possible additives couldn't be more controversial because it concerns our "Heiligs Blechle".
...WRe
...with the result that in no case did this cause any damage...
Since non-ethanol fuel isn't easy to find my Pagoda has used it for 20 years. The only known damage was a fuel hose at the tank to fuel pump at the rear of the car. But, I used marine stabilizer when storing and "dry gas" with that first tankful in spring.
I have a slew of vintage motorcycles in which I have used non-ethanol gas for the last few years. Even on a new BMW, I had a problem with a fuel line elbow, made of plastic, coming apart because of ethanol fuel. I am trying to stay away from ethanol fuel for everything that is not being used on a daily, or almost daily basis.
I've never had any problems except for the same fuel hose that goes from the pump to the main fuel line. That hose was a weak link anyway and I won't say that ethanol played a part in its demise. We will be going up to 15% ethanol in Ontario somewhere in the future. I'm not sure if that would cause problems or not if 10% didn't.
