Author Topic: Correct carpet for my 230SL  (Read 8318 times)
Montearenas
« on: October 21, 2008, 14:43:20 »
I Need a new Carpet for my new 230 SL / 1966
What is the best color and material option for this car
Somebody know :
http://stores.ebay.de/Autokraft-Autoteppiche
I can find other option
http://www.cabrio.de/Englisch/seite19_teppichmaterialien.htm
what is the correct material and color for my car?
Here you can see the current status
Download Attachment: Image029.jpg
115.08 KB
Download Attachment: Image033.jpg
149.77 KB
Download Attachment: Image049.jpg
130.57 KB
Thanks from Spain
Re: Correct carpet for my 230SL
« Reply #1 on: October 21, 2008, 14:56:30 »
You have a few choices. I am not sure exactly when the carpets changed from the "square weave" to the loop - someone here will know or you could do a search on it. The loop is certainly easier to get hold of in a range of colours.
« Reply #2 on: October 21, 2008, 16:39:54 »
The original carpet for the 230sL was a "Haargarn Boucle" carpet (commonly called "square weave" in English speaking countries). "Velour" (or "Nylon loop") carpets are appropriate for a 280SL.
The quality among currently available carpets is quite variable and my advice is to search for a carpet with a high thread count per square centimeter (= Fine Boucle) and one that has a good backing.
There are some pictures in this thread that may be of some help for you:
http://www.sl113.org/forums/index.php?topic=4824
The color code for the original carpet in your car is listed on the data card, see: http://www.sl113.org/wiki/pmwiki.php?n=DataCard.DataCards).
If you like your current brown carpet you should not have a problem finding one, or another color that you like, but I would stay away from eBay vendors.
In addition to Cabrio.de, this company also has a wide selection of Boucle carpets: http://www.werner-interieur.de/index.php?cat=4
 but you would need to call them.
Also see: http://www.sl113.org/forums/index.php?topic=6482
« Last Edit: June 06, 2012, 16:13:41 by 66andBlue »
Montearenas
« Reply #3 on: October 21, 2008, 16:47:53 »
I can see that the change are on 250SL
All 230sl and 250sl Hasta 002979 Use square weave:
And 250sl later than 002980 and all the 280SL use "2-tone-loop":
What you think about this images, it is correct??
Wthat is better option Grey or Antrazit with black seats??
Somebody have some image of the grey with black seats?? or any other option with black doors and seats??
« Reply #4 on: October 21, 2008, 17:04:48 »
Originally posted by Montearenas
..Wthat is better option Grey or Antrazit with black seats??..
Your car appears to be painted in some beige or white color, correct? It is difficult to see but are the seats and doors black or dark brown? And is this the original color combination as indicated on the data card?
Montearenas
« Reply #5 on: October 21, 2008, 17:19:54 »
The car is on White whith doors and seats in black,
The carpet have a undefined color (braun / grey / Black) in very bad condition.
I'm thinking what is the best color option for my car.
