Author Topic: Replacing gasket  (Read 2898 times)
knirk
Replacing gasket
« on: August 28, 2007, 09:47:02 »
I have a small oil leak from the vacuum control valve on the right side of the automatic gear box. I want to replace the gasket inside the plastic plate. The problem is that this plate is connected to some mechanism inside and I am not sure how much force to use to get it loose. Is it ok to pry out, or is it locked in place?
Download Attachment: box.jpg
73.04 KB
Per G. Birkeland
69 280 sl aut 834
Norway
DavidBrough
Re: Replacing gasket
« Reply #1 on: August 30, 2007, 05:48:35 »
Hi Knirk,
I replaced the same gasket on my car about a year ago and had the same problem. Unfortunately I can’t remember all the details but I did get the plate off with much fiddling and jiggling, not too much force though. I also seem to remember having to disconnect the solenoid arm at one of the ball joints. Mine has been leak free ever since.
Sorry I can’t remember any more details but hope that helps a little.
Good luck
David Brough
1969 280SL Auto with A/C
knirk
« Reply #2 on: August 31, 2007, 07:34:40 »
Hi David,
that helps a lot - thanks.
Per G. Birkeland
69 280 sl aut 834
Norway
