Author Topic: Rear Axle sliding joint  (Read 2596 times)
JGHeller
« on: May 27, 2007, 12:15:19 »
I have read that the sliding joint coupler on the right rear axle can be the Achilles heal of the single joint swing axles.  Is there any way to visually inspect it while I have my rear axle out to put in new seals, ect.
Re: Rear Axle sliding joint
« Reply #1 on: May 27, 2007, 17:32:33 »
John, Had a 111 coupe that had the bolt that held the axle in, come loose.  Put a hole the diff. case.  Gonzo!  Maybe a little Loctite is needed.
