Author Topic: Info (or trivia) on one effect of tire width  (Read 6798 times)
« on: May 22, 2007, 13:37:54 »
Possibly interesting info (or trivia) on the effects of varying tire width.  No judgments offered, just thought this was interesting.
Source of information is Dunlop Tire web site at http://www.dunloptires.com/care/widthRatio.html
“Within the acceptable range of rim widths, one can select wider or narrower rims than the measuring rim. Selection of a wider rim, from within the approved range, (T & RA tables) stiffens the sidewall and improves handling at the expense of handling (sic). If carried too (sic) extreme, either too narrow or too wide of a rim, it can result in uneven tread/pavement contact pressure causing uneven wear and potentially reduced traction, or increased vulnerability to bead dis-lodgement. Always check with your Dunlop dealer for permissible rim width options.”
“Remember - safe clearance must be determined for a particular tire/rim contender and vehicle.”
“Wider rims may offer some performance advantages over narrow rims. A wider rim increases the distance between the beads, which results in a straighter sidewall, which stiffens it. This results in quicker steering response and higher cornering forces.”
“Negatively, the straightened sidewall transmits more road shock to the wheel and suspension, placing greater stress on chassis and suspension parts and delivering a harsher ride. The straighter sidewall exposes the rim, making the wheel more susceptible to damage.”
“A narrower rim pulls the beads closer together, curving the sidewalls. This increased curvature allows the sidewall to flex more readily over bumps and absorb more road shock during driving. This offers a softer ride.”
Comment added:
From this we may infer that for a given make and model of tire being fitted on a 6x14 rim, and assuming the following sizes are available: 185/80R14, 195/75R14 and 205/70R14, then fitting 185s should result in the stiffest sidewalls; fitting 205s should result in the most flexible sidewalls; and the 195s should fall in between.
Re: Info (or trivia) on one effect of tire width
« Reply #1 on: May 22, 2007, 15:49:53 »
For my next set of tires, I had already resolved to get the original size: 185/14. Since I currently have Pirelli 205's, getting the 185's would make for an improvement in handling given what George has found. I will probably also get a set of modern springs in the next year so that should also help; I can hardly wait! Too bad those Pirellis still look like new, even after some 25K miles.
hill
« Reply #2 on: May 22, 2007, 17:48:20 »
I am running the larger tire for one reason. If you get to close to the curb the tire protects the hubcap.
Download Attachment: red5.jpg
13.79 KB
Happy Benzing
Darryl, Hill
350 SL4.5 #60
1967 250sl "California"
« Reply #3 on: May 23, 2007, 03:31:56 »
I had 205 14s on my 250sl but they were rubbing on the inner front frame and were rubbing on the exhaust pipe and giving a burning rubber smell.
I replaced them with Michelin 185 R 14 XM1s and all the problems disappeared.
I had to have the power steering box rebuilt in 2002 after it was rebuilt by the second owner in 1997.
Given the car was built around the 185 HR 14 tyres, the wider tyres probably add extra work for the steering box.
« Reply #4 on: May 23, 2007, 06:18:00 »
Here are some other factors to consider when buying tires.
www.toyojapan.com/tires/pdf/TTT_08.pdf
nick350
« Reply #5 on: October 13, 2007, 12:33:37 »
Hill..do you have a bigger photo of your car with the wider tyre on it?
13.79 KB
Happy Benzing
Darryl, Hill
350 SL4.5 #60
« Last Edit: October 13, 2007, 12:34:06 by nick350 »
