Author Topic: hard top hoist  (Read 6505 times)
69280sl
  • USA, IL, Elk Grove
hard top hoist
« on: November 15, 2006, 22:12:46 »
At various times, there have been discussions of hoists, storing the hard top, etc. I would like to share my hoist idea which is cost effective and efficient (if I do say so myself).
The heart of the hoist is the 440 lb hoist offered by Harbor Freight. When it is on sale, which is most of the time, it is about $60.
This hoist runs fore and aft, suspended from a 1" pipe which is itself attached to a 2x8, which allows spreading the load over 5 ceiling joists. The ability to move the hoist makes positioning over the car easier and allows the suspended top to be moved out of the way of the overhead door.
The "hanger" bar I used is from a manual hoist, but I believe a roof top carrier can be used since all it does is grab onto the drip rail.
One change I made to the Harbor Frt hoist was to change from single sheave pulleys to double sheave. This cuts the speed in half and makes control very easy.
Installing or removing the top is an easy one person job and takes less than 2 minutes start to finish. And of course the stored top doesn't take up any useable space.
http://i21.photobucket.com/albums/b284/inspectorgm/100_0961.jpg
Gus
68 280sl, signal red/beige
Gus
rob walker
Re: hard top hoist
« Reply #1 on: November 16, 2006, 02:08:31 »
Gus, nice job, interesting for us getting older!
Rob Walker
2004 230 SLK silver
ChrisInNashville
  • USA, TN, Nashville
Re: hard top hoist
« Reply #2 on: November 16, 2006, 02:38:03 »
Wow, I stand in awe!
I go into a panic when the chalk on garage floor (that marks the PRECISE spot where the four tires must be to get safe lift) gets wiped off!
‘69 280 SL
‘24 GLE450e
Tennessee, USA
Re: hard top hoist
« Reply #3 on: November 16, 2006, 09:58:58 »
Gus,
This was a perfect post for this thread:
http://index.php?topic=5559
BHap
  • USA, PA, Pittsburgh
Re: hard top hoist
« Reply #4 on: November 16, 2006, 12:03:45 »
Nice job Gus - how do you attach / move the hoist on the 1" pipe?
Bob Happe
Pittsburgh, Pa
Bob Happe
Pittsburgh, Pa
69280sl
Re: hard top hoist
« Reply #5 on: November 16, 2006, 16:50:35 »
Rodd: Sorry I missed the previous thread you referred to. I certainly would have piggy backed onto it.
Bob: The hoist hangs off the pipe from the semi circular brackets that come with the HF hoist. Being in the garage, I push it into position with whatever comes to hand (like the tine end of a rake). Not precise, but adequate.
Gus  280sl
Signal red/beige
280sl
Gus
Re: hard top hoist
« Reply #6 on: November 17, 2006, 07:46:26 »
My hardtop seems to balance on the rear latch pins.  Is this true for all tops?
Re: hard top hoist
« Reply #7 on: November 17, 2006, 09:16:46 »
Mine almost does (230SL top w/ fixed handles).  The front falls to the floor, but not with a lot of weight.
