Author Topic: Spare Tire Cover  (Read 6735 times)
Spare Tire Cover
« on: June 19, 2006, 12:58:03 »
I just saw an OEM spare tire cover on a 1970 280 SL that didn't have the channel in the flap for the lugnut wrench. Seemed odd to me. Has anyone else ever seen one like that?
113gray
Re: Spare Tire Cover
« Reply #1 on: June 19, 2006, 17:53:55 »
Mine has no such channel. Lugnut wrench on mine is secured to the trunk floor in metal clips beneath the horizontally mounted tire.     -JP-
« Reply #2 on: June 19, 2006, 18:57:18 »
Mine is the same as JPs
« Reply #3 on: June 19, 2006, 19:29:57 »
Mine seems to have both. The lug wrench has been in the single black metal clip that is at the floor of the trunk, about midway left to right, below the latch since I got the car.
After reading this thread I went to the garage for a look. The spare tire cover has a long, narrow pocket sewn in at the "hinge" of the fabric that the lug wrench fit nicely in to, althought the head of the wrench sticks out of the flap when snapped.
I then took it out and clipped it back in its place. ;)
1973 911S
2004 A4 3.0
2006 GS430
« Last Edit: June 19, 2006, 19:30:20 by Ed Cave »
« Reply #4 on: June 19, 2006, 21:14:18 »
Thank you for checking. That's interesting how some spare tire covers have it and other don't.
(By the way, I believe that metal clip where the trunk floor meets the inner tail panel is for the luggage strap. You'll see its mate for the other half of the strap directly behind it towards the back of the trunk.)
« Reply #5 on: June 19, 2006, 21:47:37 »
So Douglas, should I then assume that my lug wrench should be housed in the spare tire cover, slid into its sleeve with the head of the wrench sticking out of the cover when snapped shut?
I am curious now, and would prefer it appear properly when the car is shown.
1973 911S
2004 A4 3.0
2006 GS430
« Reply #6 on: June 19, 2006, 22:31:27 »
Ed and all,
my spare tire cover has a hole in the lug wrench pocket, maybe 3 inches from one end.  I think the lug wrench goes in here, that way it doesn't stick out.  The 3 or so inches left unused "might be" for the wheel centering tool(?).
« Reply #7 on: June 20, 2006, 05:48:35 »
The setup George describes is exactly right, of course. (He always is.)
If you don't already have a wheel centering pin, you should find one from ebay or the usual sources. It's a nice detail to have among your Hazet tools. Plus, it's kind of nice to see how it fits so perfectly in that little pouch in the spare tire cover flap.
« Reply #8 on: June 20, 2006, 06:30:21 »
I thought the Lug wrench fitted into the slot of the tool kit and the wheel centering pin fitted into the same tool kit.
« Reply #9 on: June 20, 2006, 07:21:17 »
I think we've just established it could be either way, since some of the spare tire covers don't have the necessary pockets.
Here's a photo of that wheel centering pin, in case anyone is wondering:
Download Attachment: 41_1.JPG.jpg
27.11 KB
« Last Edit: June 20, 2006, 07:22:11 by Douglas »
Vince Canepa
« Reply #10 on: June 20, 2006, 09:00:10 »
The lug wrench doesn't stick out of the pocket if it is inserted with the socket end "inside" - i.e. it hangs into the well inside the spare tire cover when it is snapped closed.  If it is inserted with the socket end "out" it may touch the deck lid with a corresponding dent - not good.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
« Reply #11 on: June 20, 2006, 09:28:27 »
Douglas, I appreciate what you wrote, but I'm not always right.  Post less = fewer opportunities to be wrong!
« Reply #12 on: June 21, 2006, 05:28:20 »
27.11 KB
Hey Douglas,
I bought a centering pin for $5.00 from a wreckers' yard. It originally came from a sedan. I also bought the rubber mounting bracket that fits to the internal boot rear wall. It is a great place for the pin and the bracket keeps it always in the same spot.
There is a small cutout that the bracket fits into.
113gray
« Reply #13 on: June 22, 2006, 09:55:21 »
Eating humble pie here w/ crow for dessert! I checked my sp. tire cover again & it DOES indeed have the pocket. I have seen it previously dozens of times & thought it simply a reinforcement. My bad!       -JP- '66 230SL Euro
