Author Topic: Hardtop Dolly - Dimensions  (Read 7542 times)
« on: September 15, 2005, 01:42:15 »
I'm thinking about custome-making a hardtop dolly (It's too bulky to import). Anyone tried this? Anyone knows the dimensions?
Mo
'69 280 SL Silver/Black
Re: Hardtop Dolly - Dimensions
« Reply #1 on: September 19, 2005, 18:06:17 »
I made mine from lumber.  Want any dimensions or costs?
Download Attachment: Copy of IMG_2764.JPG
40.52 KB
Download Attachment: Copy of IMG_2765.JPG
43.28 KB
saygold
« Reply #2 on: September 20, 2005, 10:00:12 »
Rodd,
I built a hardtop dolly a number of years ago, but left it when I moved.  I would appreciate having the dimensions of yours.
Ken
'66 230SL (white, euro and running)
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #3 on: September 20, 2005, 17:01:28 »
I bought a flat furniture dolly from Harbor Freight on sale for $17.  I used it to move the donor engine around my garage while doing my rebuild.  My plan is to use that as a base because it has great casters, and is made of nicely finished plywood and padded with carpet.  You can't buy the parts for $17.  All I need now are the dimensions to build uprights.  I am thinking about galvanized water pipe with foam pipe insulation.
'68 280SL 4-spd Coupe
« Reply #4 on: September 20, 2005, 18:29:15 »
The dolly sold by Buds Benz is a simple design.  It's made from pre drilled  flat bar that the consumer assembles. In some areas where one bar is not enough to carry the weight there are three bars/pieces stacked together.
I did not hold onto the instructions but perhaps one of our members may have one.
« Last Edit: September 20, 2005, 22:05:00 by hauser »
tuultyme
« Reply #5 on: September 20, 2005, 20:40:55 »
Here are pictures of how I store my top for the summer.  I do not have enough garage floor space.
Download Attachment: top store B.jpeg
52.17 KB
Download Attachment: top storage A.jpeg
64.77 KB
I mounted a ununsed personal water craft lift on the side of the garage; used a lot of lag bolts.  I did build a frame to accommidate the top on the lift.  One day I might build a manual lift to get the top from the car to the storage rack.
andre
« Reply #6 on: September 27, 2005, 12:51:51 »
Rodd,
What are the weight bearing areas on your " top dolly"?  That is similar to what I was looking to build, I'm just questioning how to distribute the weight of the HT.  Can you provide more pics and maybe some close ups?
andre
« Reply #7 on: October 05, 2005, 19:01:10 »
Andre,
I traced the curve of the back of the hard top (below the rear glass) and cut a pair of 2" x 8" boards to match as best I could.  This was an attempt to distribute the weight across the width of the rear chrome trim.
The base of the "cart" is a 3/4" plywood at 24" x 60".
Download Attachment: Copy of IMG_2779.JPG
44.11 KB
The wood around the edge of the base and the verticle pieces are 2" x 6".  I have a metal angle bracket at the back.  The verticle pieces are 48" long and rest on the lower 2x6.  There is another 24" x 60" piece of plywood on the back for stability.
Download Attachment: Copy of IMG_2782.JPG
56.21 KB
I should buy a proper cover for the top while it's stored on it's cart for 8 months of the year.  I just drape the blanket over it.  Here's a couple more shots.
Download Attachment: Copy of IMG_2781.JPG
49.67 KB
Download Attachment: Copy of IMG_2785.JPG
38.67 KB
Download Attachment: Copy of IMG_2786.JPG
49.52 KB
« Reply #8 on: October 05, 2005, 21:36:51 »
Bruce,
That's really cool!
« Reply #9 on: October 08, 2005, 08:12:09 »
Thank you all for the very informative -and innovative- ideas. I appreciate it.
Mo
