Author Topic: Girling Calipers?/ Recommended Pads  (Read 1562 times)
miniwarmth
  • USA, IL, Olympia Fields
« on: September 26, 2025, 15:08:46 »
Hi All,
Was refreshing my brake fluid yesterday and noticed my current pads are getting thin (yikes). Wish i had a set of replacements on hand but i didn't.
I have a 64 230 and in looking at the pics / comparing to BudsBenz they seem to match the Girling calipers.
But the actual pads/mount looks a bit different than the images.
See attached image of my caliper.
https://www.budsbenz.com/catalog/230-250-280-sl/k-brakes/K223-002
Is Budz my best bet here or is there something just as good and available more quickly/locally - am in the chicago area.
Nik
'64 230SL
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
Re: Girling Calipers?/ Recommended Pads
« Reply #1 on: September 26, 2025, 15:55:35 »
Pelican parts sells the girling brake pads, youmight also check with Mercedes Classic center
Lori
1968 280SL (US)
miniwarmth
« Reply #2 on: September 26, 2025, 16:43:38 »
Thanks! I guess my question is that the calipers look to be girling but when look at the pads shown online, the way that are installed (the mounting holes) look a lot more like the ATE ones.
Here's an image to illustrate my confusion ( :o :
https://imgur.com/a/gurk6vS
« Reply #3 on: September 26, 2025, 19:20:01 »
I have the 3-piston Girlings as well.  Haven't bought brake pads in forever.  Many people buy parts from Authentic Classics.
https://www.authenticclassics.com/category-s/54.htm?searching=Y&sort=13&cat=54&search=Pad&show=56&page=1
Don't worry about buying local, worry about getting a vendor who knows these cars and parts, and communicates well.
« Last Edit: September 26, 2025, 19:32:05 by rwmastel »
BobH
« Reply #4 on: September 26, 2025, 19:55:56 »
Your calipers look like ATE to me
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
miniwarmth
« Reply #5 on: September 30, 2025, 18:56:09 »
I think you are correct - these are ATE calipers!
https://imgur.com/a/sYz2S0S
Pads ordered!
« Reply #6 on: September 30, 2025, 19:33:06 »
They are ATE.
More common, easier to find brake pads, and less cost to rebuild.
« Reply #7 on: October 16, 2025, 10:54:26 »
I just completed a full rebuild of my braking system. ALL ATE PARTS where applicable:
Pads
Fluid
Master cylinder
Coated rotors
Calipers rebuilt including factory plating (cadmium not zinc) by Caliper HQ.
New bearings in front
New flex hoses all around
New reproduction fluid reservoir
Everything is easy to find.
ATE logo is embossed on caliper casting.
