Author Topic: IN NEED OF A BRAKE BOOSTER  (Read 727 times)
duke
  • USA, IN, Indianapolis
« on: September 19, 2025, 15:17:57 »
I HAVE A 1964 230SL.  MY car is at the Mercedes service shop in Indianapolis to have the brakes repaired.  They have told me that I am in need of the Brake Booster and the supply line.  The  service shop in Indianapolis says that none are available thru their sources.  Does anyone know where i might be able to locate the Brake booster and supply line?
dirkbalter
  • USA, CA, Corona
Re: IN NEED OF A BRAKE BOOSTER
« Reply #1 on: September 19, 2025, 15:24:29 »
Yes, they are hard to find and almost impossible to find new.  You may want to consider having yours rebuild. I don't know about close to you, but there are a some companies that rebuild these.
Make sure your old one, especially the plastic / bakelite parts don't get damaged while handling the booster.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
baon3h
  • USA, CA, San Francisco
« Reply #2 on: September 25, 2025, 00:07:15 »
Not sure if this is something you would consider, but I replaced my brake booster with an electronic brake booster (no vacuum required) from a Tesla Model Y.
 See https://www.sl113.org/forums/index.php?topic=39473.0
Moe
1968 280SL Manual
Peter h
« Reply #4 on: September 25, 2025, 10:39:21 »
We rebuild them here in the UK but if you do a search on this forum I'm sure you'll find a company in the USA that rebuilds them.
JedinDetroit
  • USA, MI, Harrison Twp
« Reply #5 on: September 25, 2025, 22:29:05 »
Get it rebuild. I had one rebuilt here in the states a few years ago. Quick turnaround and I don't remember it being outrageously priced. I am sure I can look up the rebuilder if needed.
1965 230SL Euro
1966 250SE
clunker
  • USA, NJ, Chatham
  • 1969 US 280SL 4-speed
« Reply #6 on: September 25, 2025, 23:25:11 »
https://powerbrakestore.com/ worked well for me - fast and reasonable
Charles
1969 US 280SL 4-speed Red/Black
DB9 / 981 S / G300 SWB / CB750 / etc
« Reply #7 on: September 26, 2025, 00:04:26 »
dirkbalter
  • USA, CA, Corona
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Peter h
« Reply #9 on: September 27, 2025, 03:38:13 »
Yes, for the t52 you need the late bracket A113 435 0440. Unfortunately, it's hard to find. The t52 offered is also just a replica. It's all complicated, I just wanted to point out another possibility.
RobParkerMB
  • United Kingdom, England, Taunton
« Reply #10 on: September 27, 2025, 10:30:15 »
Why did they tell you to get a new one... What are your symptoms?
1964 230sl
1998 sl320
2003 e320
2010 e350
mauro12
  • Italy, Sicily, Messina
« Reply #11 on: September 30, 2025, 10:53:03 »
Guys What Is the brake booster model for 230 and 250? The t51 or t52 ? I believe that the 280sl has a different type of booster . They are not interchangeable? Do you reccomend a company in Europe who rebuilds these units ? By the way I’ve tested mine and at idle I have a vacuum between 400 and 500 mmhg which should be within specs . I’ve noticed that after replacing last week all brakes components ( discs , pads , hoses and master cylinder, the brake pedal seems to be harder . I don’t know if it’s only a feeling..  any advice is appreciated
Mauro Pisani
250sl 1967 5speed zf manual
« Reply #12 on: September 30, 2025, 19:54:50 »
MY car is at the Mercedes service shop in Indianapolis to have the brakes repaired.  They have told me ...
What is "the Mercedes service shop"?  Dealership?  Independent shop?  Friends house?
