Author Topic: Chrome bezel came off tachometer  (Read 489 times)
CJHenderson
  • USA, AR, Benton
« on: September 16, 2025, 00:33:12 »
When installing the tachometer, the chrome bezel fell off. Ordered a new one, just like the old one which I crimped on I would most likely have the same problem. Would it work if I placed the tach face down an apply a thin adhesive between the bezel and body of the tach?
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
Re: Chrome bezel came off tachometer
« Reply #1 on: September 16, 2025, 04:37:57 »
Why would it come off if you crimp it? I understand you use the round grey gasket\liner that goes there between speedo and dash? It is just hand tight fixing, the bezel should not come off when crimped…
« Reply #2 on: September 16, 2025, 07:08:31 »
As Pawel says, and for that matter you should be able to crimp the old bezel back on without issue also.
CJHenderson
  • USA, AR, Benton
« Reply #3 on: September 21, 2025, 21:40:29 »
Thanks to all I followed your advice, and it did the trick. Now I'm a proud owner of a new chrome ring but I'm confident it will migrate to Ebay.
1950 MG-TD
