Author Topic: Input Shaft Seal - manual trans  (Read 449 times)
kampala
  • USA, CA, Hermosa Beach
« on: August 23, 2025, 19:50:54 »
Need some advice.  I have read the difficulty with installing the input shaft seal and plan to make the hole-saw tool or the pvc pipe tool to install.
How can I remove the seal?
I have this tool to help but no luck.
250sl - later - manual
280sl - 1971 - Auto - LSD
Re: Input Shaft Seal - manual trans
« Reply #1 on: August 26, 2025, 05:49:19 »
Take a flat nose round drift (about a 1/4" diameter) and drive it inward at one spot on the seal. it will, after a few taps deform enough to easily be removed with pliers or hook tool.
kampala
« Reply #2 on: August 26, 2025, 14:28:42 »
Joe,
Appreciated.   It worked.
Thanks much.
Now to get the new one in!
« Reply #3 on: Today at 04:27:35 »
The factory had a special tool. I found a hole saw just the right diameter then ground the teeth off and used it to drive in the new seal.
« Reply #4 on: Today at 04:51:21 »
I made one on a lathe knowing I would use it many times. It was a good decision.
I use a bit of sealer on the metal portion of the seal during installation.
